Got around to fixing the passenger side. I had previously ordered both sides and both upper and lower brackets, but only tackled the driver side. The passenger side was a mystery because it appeared solid, but I remembered having it come loose while rig was in motion and damn near having it fall and hit the ground before I could get stopped. I was on a washboard road sailing along at a pretty good clip when it happened. By myself, when it broke, and I heard it hit the door - it was dangling by the wires
. I remembered that, but not how I fixed it. So, I dug into it and wow, I was glad I did. I had done my own patch job and this was back around 2005, before I found Mud or even heard of the "zip tie fix". I must've used a whole tube of silicone seal on it
to hold the bottom broken support in place and cushion the rear corners of the motors assy around the metal bracket. I had even used a couple of zip ties (before somebody suggested to fix the shakey mirrors with them), but I had really snugged them tight, so it was a bear to get it apart. 1st step was to remove the bottom screw. I got kind of suspicious when it wouldn't budge with the screw removed. So after prying the mirror up and seeing the ties, I cut them and the silicone just kinda came apart in pieces when I yanked it out. Well anyway, it's held up for almost 15 yrs, but I have to admit - it could've broke again at any time, "fixed" like that. Outsane's fix on this side went in easier than the driver side, but it's just as secure, now. Got more confidence on washboard, now - at least for the mirrors
. Thanks @Outsane for your work and making it available at a reasonable price!!!
