Shackle mods
Oregon Coast
Hi all!
I'm relatively new to this, I bought a 74 FJ40 last year and haven't had much chance to do anything to it until now. One of the things I've noticed and would like some help with are my rear shackles. Below are a couple pictures I took of how they're sitting now. It doesn't look right and you can see that they've been hitting the hanger quite a bit (not so amazing considering there's only a half in gap at rest). I think the PO put a 2.5" lift on it but I can't be certain of that, but I do know that it sits higher than a stock setup.
I've been thinking about getting either some longer shackles for the back (The front already has longer ones) and have also considered the "compound"? shackles. I've read on here about those and it seems that most people who have posted don't like them. What should I do? Keeping in mind that I don't have the knowledge or funding to change everything at once.
Thanks, and I look forward to hearing what you have to say.
Wow! You are correct, your shackle length and angle is terrible. It looks like those springs may be for a different application than a 40. You *may* be able to get away with some much longer shackles or "revolver" type shackles but you may have to install some shorter springs or flip the rear frame mount.
I agree with John, but definitely try longer shackles first. How does the front look?
Ed
This is the front. I think it's better, but just because it isn't hitting anything. Aren't they supposed to be at a 45 degree angle?
I may be wrong here but if you look at the 2nd pic, it seems that the spring pad is angled backward quite a bit? to me this doesn't look right, it looks like your axle is rotated forward somehow pushing the spring pack rearward? Am I incorrect in stating that the bottom ubolt plate should be sitting parallel with the ground?
Noah
Noah
I think that whole picture is just crooked from the camera not being held straight. Look at where the floor and wall meet in the background.
Those rear springs do seem long.
Yes, the camera was just crooked. I guess I'll never make a living as a photographer.
i would try a longer shackle first, then you can move the hanger if that doesnt work
I might be looking at this wrong, but it looks like you have too long of shackles in the front, giving you poor angle, and too short in the rear, giving interference.
could you just swap them front to back??
might need to go still longer for the back.
somebody on here (Mark W ?) has spoken in favour of just using flat stock, (3/8 x 2" x length you need) for the shackles, that would be the cheapest option for sure.
Flat stock works well. The place I got mine even cut them to length in their shear.
I'm sorry to illustrate my ignorance, but by "flat stock", you're referring to the schackle being unreinforced, without a peice that connects the two sides?
Yes. And try the longer shackles in the rear first for the cheap fix.
Aren't flat stock shackles inherently less stable than "reinforced" shackles? Is that good?
Shackles with the crioss piece have a number of disadvantages. I'm pretty sure I've discussed it recently here on Mud. A search should pull it up.
Longer shackles will solve your problem in the rear perfectly. I'm running springs that are 6 inches longer than stock, using longer shackles.
You need to make your shackles long enough so that the spring can go flat (that's its longest) without the shackle hitting the frame or for that matter camming over.
You'll hear 45* tossed out a good bit as an "ideal" position for the shackles. I've probably done it myself in the past. But it's not really that definite. But I do pefer to see a shallower angle than what you have in the front. What you have there is not unusual or unacceptable, but a bit shallower would be better. Are the front springs original or are they lift springs of some sort. Maybe stock w/add-a-leaf?
Mark...
Not nearly long enough to be '55s. And '45s are even longer. Those are just barely longer than stock.
Mark...
