use some 3/8" steel and a some bolts that are the same size as stock springpins (14mm?) Should be a great fix. I made mine and they look pretty good. If you can keep from running a cross piece you'll be better off but sometimes that's the only way it can be done.![]()
stock shackle pins are 14.7~14.8 mm. don't know why toyota chose a wierd size but a 9/16 bolt (14.4 mm) would be a closer fit than 14 mm
