Shackle Angle correction
Phoenix, AZ
Guys
In the process of my spring lift, it was noted that my shackle angle needs corrected. Currently they are pretty much vertical and/or reversed a bit. They have settled a bit since these photos were taken. So it seems that slightly longer shackles would be the easiest way to achieve this. How much more length would I need to correct these? Recommendations on shackles???
FJ40 Lift
Thanks,
Robert
1962 FJ40
A shorter shackle might give you slightly more angle, but your shackles look pretty short already.
The rears are definitely no bueno. New springs will settle some, but not enough to help the rear. Moving the shackle hangers towards the axle will improve the shackle angle and function.
IMHO, the main leaves are too short for the arch they put in the springs,
Maybe this helps: Rough Country 4” spring dimensions
So, about shackle length about 4.5” pin to pin is minimum for the rear springs. But it won’t correct the angle. Take a leaf out of both rear spring pack, it would help a lot for driving comfort too.
That was my next question. Any thoughts on which spring to remove? Also do you not think the front should be adjusted in a similar fashion?
Robert
Anti inversion shackles prevent the shackles from flexing in and locking.
With longer shackles you change the caster since only one of the spring is moving. Wedges where the springs attaches to the axle to correct this. You have to figure the amount of change and then get the correct wedge to bring it back to stock.
Robert
I took the second shortest. The front is not so bad, but it’s worth trying.
And just how do you do a Castor correction?
Robert
Like said, caster shims. The original caster is only about 1°, now you have 0° or -1°. Something like 3-4° would be better, especially if you have bigger tires. Here is an example: Axle Degree Shims 2.5" Wide, 4 degree, steel wedge, caster pinion angle WFO 4.0 | eBay
I fought the same thing when I put new springs on my 55, I had already traveled too far down a path to start over so I had to move the shackle hanger to accommodate my springs.
I link the calculator I used to figure the shackle length in post #787.
Awesome...square cut leaves...that's why they call them Rough Country
Actually, an inch longer shackle will help. The angle will improve in a little time .The stock shackle is too short
for a lift spring.
Regular or inversion doesn't matter. If you do a longer shackle in front get the 2 deg shim @-MaTTi- suggested, or similar
Looks like the rear spring pack is too short. Manufacturers design error. What brand are they?
Rough Country 8042. They are longer than some other 4" spring pack, but they are more like 6" when new. That´s why they look too short.
Here is BDS 4" spring, which is about 1/2" shorter, looks about right:
