Seat Identification & Questions
Are these seats from either a 1971 or 1972 FJ40, and no other year? The backs are metal, painted the same color gray as the frames.
Does the vinyl look original? It's black.
I have a 1961 FJ40 with torn and beat up bucket seats. The seats below are closer to what belongs in my 40, but still obviously far from correct. I am not sure what to do with them. If I decide to sell them or use them as barter, what would be a fair value for these seats?
I think the year range is earlier. That driver seat is for a tub with a foot locker. 72 had no lock box.
They should be later than 1966. My driver seat has round-tube frames. Your pic shows rectangular seat frames under the driver seat.
I'm no expert. I only know what I've worked on (a 72 and a 66).
some incorrect information here - and what is a foot locker ? you mean the tool box ? '72 in the US had a tool box
this looks like an OEM Toyota three piece front bench found in late model '71 and up to 9/'72 FJ40s
the middle seat back has the evaporation device that returns condensed fuel vapor to the gas tank - you want to keep this function
I have been told that vinyl was stock (as far as I know in salmon orange color), but my cruiser came with blue fabric on this bench/seat combination
the driver's seat is attached to the top of the underseat tool box - you can see the handle for the seat slider mechanism in the bottom of the mounting frame
in the shape it seems to be in, this will be worth quite something to someone restoring a '71/'72 cruiser to OEM condition - I do not recall how much the last bench like this sold on MUD fetched, sorry
The seats were a dark grey starting with the 68 model. That was also the first model year the seats truely locked in the upright position. The handle on the lock was a plastic T shape. With 71 model the lock handle was slim against seat. I have yet to see a picture of a 71 passenger seat that had a one piece back. All have had the small fixed portion. Other markets may have had them. US may had too but never seen one.
Here's my old seat. I have a 6/71.
merlinridesagain said:
That looks pretty much the same as my 8/71, but nicer...got some PO captive nuts to clear before I can get the backs in again...
with a seat hook that looks like this:
My 4/71 has the same seat hook / latch, but has the earlier bench passenger.
mine looks the same as SouthBoston's - except it is blue cloth and the metal pieces are covered in blue vinyl
the seat switch is stock - except for two bolts that are not
My March 71 40 has the single full width passenger side seat back. The upholstery is black vinyl.
The driver seat actually rests on the toolbox top and fastens to the front side of the toolbox itself, not to the top as stated earlier. The rear has pins that fit into a set of brackets mounted to the floor so the driver seat is setup for quick removal.
My '72 has the same seats. Driver's seat attaches to tool box via two "lunch pail" type latches in the front and removable pins in the rear for quick removal. Seat back tilt lock latches are bare metal.
Sale? Barter? Where are you located?
Those are in pretty nice shape. :D
Has anyone got A 71 that has 3 independent seats up front? No bench.
Will I find a single narrow seat cover?
It orig had the long rear bench seats.
Was the intention to make a 7 person 40?
1 seat goes over the tool box
1 seat is about 16" wide
pass seat is same as the drivers' side
both pass and drivers are forward folding
3 on tree
no sticks in my tunnel
Thanks
1 seat is about 20" wide
pass seat is same as drivers side
3 on tree
Thanks
My 71
I just put these on eBay last night
