The biggest advantage you get with that alternator is the power at idle. The alternator uses the hairpin windings. More efficient than the old school delta or tri windings.
I'm running a Tundra modified to hairpin windings. On my alternator load test, I put out 102 amps at 700 rpm and 227 amp at 2500 rpm. I don't need and cant use 200 amps but, I have a trailer. 2 batteries there and 2 in vehicle. "IF" both batteries in trailer are very low (Parked in forest) the max draw from them will be about 40 amps each plus my fridge. If I have one or both in the vehicle low, that can be as high as 160 amps, total max draw from alternator. Now factor in slow off road driving and a normal alternator wont keep up.
The point is, your stock alternator is designed to maintain battery charge and run the vehicle once started, not charge a very low battery. With a stock alternator with an 80 amp output, one low battery driving down the freeway (max output) the alternator is happy and you wont burn out the stator. Add in another low battery and now your running at max output. If your lucky the stator wont burn.
In my case, I don't have a stock vehicle. My electrical system is modded. Stock doesn't cut it. I know the responses I normally get are "I've been running stock for 100 years and I don't have an issue".
Starting in the 70's I have been upgrading alternators to match my needs. In the shop, I had seen enough burned stators with 60 amp alternators. The customer jump started the vehicle then hit the highway. Alternator hit close to max output for too long and fried the stator.
So, does the alternator fit your needs? If so look into it. I would suggest you research hairpin alternators. The prices have come way down. Something in the 120 -150 would rock for us if it bolted in. I wasn't able to find a well priced direct bolt in. The Tundra Alternator I bought, I think was under $350 when I bought it 2 years ago, plus the conversion. The 220 amp was the lowest output and the most reasonable. I found the same alternator as high as $1200 dollars.
