Build Samurai on Toyota axle build
Member Build Threads
My full hydro setup from Trail Gear
ry%3D400
ry%3D400
ry%3D400
ry%3D400
Disk brake set up for the rear. I bought the bracket from Sky Manufacturing and the calipers & rotors are Cadilac Eldorado fronts
ry%3D400
ry%3D400
ry%3D400
Front
ry%3D400
ry%3D400
ry%3D400
Hydro Obital box
ry%3D400
ry%3D400
As for comparing the KRC pump to the PSC pump the PSC puts out more but I'll take the KRC mounting bracket and hardware over the PSC mounting anyday
Got all the Hydro Lines hooked and it works great. Also bulit my battery boxes.
ry%3D400
Workin on the rear getting everything diamond plated in and mounted the fuel cell
ry%3D400
It is now finished
ry%3D400
I have some serious turning radious
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
sweet, i need to find another sami
If you ever want to trade for an FJ40, put me on the short list. Very fantastic!
Thanx guys. I worked my a$$ off on this thing and made sure it was built right and not half a$$
Those Full hydro links always point backwards?
Most of the setups I've seen are point back a bit. I couldn't really put it back any further because of the housing.
Most good setups point forward towards the steering arms while the tires are straight ahead, that way, they do not point backwards when the wheel is turned (most stress).
You may want to keep an eye on those to make sure they are holding up. There is a good chance it will fail on ya.
:beer:
any problems with the orbital mounted to the frame and the rest of linkage attached to the body (frame and body flex)?
Looks freakin great by the way.
just like a standard gearbox is mounted..
My 40's is like that. no problems what so ever.
:beer:
I'll keep an eye on that
sweet build up and all in a few days. :hillbilly:
what knuckles and knuckle arms are you using on the diamond housing?
i like the full hydro set up and i am considering this for my yota front axle. but i feel like i have to beef up the arms and knuckles to run full hydro.
Have you thought about adding rear steer?
I still have the stock knuckles and the Trail gear hi steer. I just bought the 6 shooter knuckles from them just haven't had time to put them on. Thought about the rear steer but not anytime soon.
