Safe to air down?
Los Angeles, CA
Hey guys, question. I picked up a used set of beefy Toyo open country MT. After getting them mounted I noticed what seems to be gash in the sidewalk. It doesn't seem deep at all and the tire holds air just fine. Is this tire safe to air down on the trail? Is something to back fill it with? Any advice would help. Thanks in advance
Airing down wont kill you going 75 and having a blow will. Time for a new tire in my camp. What is the date code on the tires?
If that’s a gash in the “outter rubber only” and not the actual sidewall, is there any downside to running it? At that point “technically” it would be cosmetic.
Additionally, this is throwing aside any date codes and actual dry rotting of the tire. Ultimately, it’s better to err on the side of caution if not cosmetic
I had irok radials split like that on my garage queen. I had two let go in separate occasions, both on the front, at highway speed with absolutely no drama. Simply rapid air loss.
Blow-outs occur due to internal damage (ply slippage), not external cosmetic, and exessive heat (psi).
For the original poster, the unknown is how that occured. A careful inspection would be in order but it will never be known unless the seller can honestly say.
Put that to the outside of the wheel, and move it to the driver's side rear. That way you can keep an eye on it if nothing else.
But safer to not run it. I would not want to be near you in a catastrophic event.
Put it on the right rear and run it. If it blows, it's on the rear and remains controllable. When it pulls after it blows, it pulls you AWAY from traffic, not into it.
I don't know if anyone can give you valid advice from just that picture. I'd go to a tire store I trusted and ask them. I think you'll be just fine, but let someone who can actually see the tire and knows what they are talking about tell you.
But there are some good suggestions here. Yes, OK to air down. Second, if possible, make this your spare. And if not, run it on the rear.
Can you put the blade of a screw driver in it, pry it open and see cord? If so, that thing is good for trail use only. If not, keep a close eye on it because the tire will flex as it rotates and that flexing could make that crack deeper.
I had a set of 37x13.5R17 mud grapplers on fjcruiser rims...
The rims were too narrow for the rubber and all the tires developed splits like that, eventually one started leaking loudly but without any sort of damage or delamination at highway speeds. Loud enough I could hear it from the cab, just pulled over and swapped the spare.
All the tires had much worse cracks than that, many of them it turned out and on all tires, and was due to wheels being too narrow.
Personally I would just run the tire, and air down as needed, as long as you have a good spare. I really don't think that would cause a blow out or delamination, but you should make that call. If you have a matching spare and you are concerned, then just run the spare and use that one fully aired up as a spare. Or buy one more tire and use it as a spare. But after my experience I would be more concerned about if the wheels are too narrow and damaging tires than a blow out or airing down, not sure what your setup is and if that will be an issue.
I feel like you wouldnt ask if you thought it was fine. 'Mud preaches safety. Also, Id wager most have violated safety best practices at one time or another. Personally, I draw the line at protecting my passengers; on any car. I dont risk my passengers.
I just wouldn't run it. I don't like the way it looks, and my safety and that of those around me is too important. Even if it just lets go on the trail, unless you're on a flat spot with nice side access to change it, it's going to be a huge PITA to change it out. And then you'd have no spare as you just used yours. It just doesn't make any sense to me to run a tire that looks like that. Better safe than sorry.
I say get a new tire, having had a tire blow out at 50mph (not fun).
Thank you very much for all of the input guys, much appreciated. I do need to buy a 315 spare so i will end up using this tire as the spare and buy a new tire. I did reach out to the original owner and he said the tires are only three years old and that he did not notice the crack/tear prior to sale of he wouldnt have sold it. I did not notice it either so it turns out to be an "ahh s***" moment. Surprisingly though he said he will reach out to a few buddies that are toyo sponsored to see if they have a 315 around and if so he will deliver it for the hassle.
