POPO AGIE
Full floating axles are rare in the States except for FJ80 axles.wouldnt it just be easier to buy a toyota ff rear axle?
I would really like to use the original axle housing, and my welding skills are on par. I just need to get some exact dimensions so I will know how much axle tube to cut off. I would also need to know the dimensions of the custom axle shafts.
With the rotors on
Is this kit for a LandCruiser? or will it fit both the LC and Hilux?
This should help.Toyota Axle Widths: 21 of 'em for Axle Swaps
The most Toyota axle widths you've ever seen: Specs and gotchas for minis, 4Runners, Tacos, T100s, and 40, 55, 60, and 80 Series Land Cruisers.www.roundforge.com
Cruiser Parts have full floating FJ40 axles but they start at $2500 and go up from there. SOR lists them, but they are always out of stock. With today's shipping costs it gets expensive very fast. I did some research and figured out how to convert a semi float to a full float. I saw an article from over 30 years ago where they converted a Jeep Wagoneer rear axle to a full floater. But getting customer axles would have been harder now, but the market has caught up and parts are more available to get it done.Unfortunately, this is true. (Of Toyota's or other small trucks/Jeeps) Common on 3/4 ton and larger. I always say we get the crap here in the States. Everyone else gets the cool stuff... especially Australia. (except for that dern steering wheel on the wrong side![]()
You do not need the 3rd..the one you have will work with zero modifications.Holy Cow! Cruiser Parts has everything! Thanks for the info! It might be worth my time just to buy one from them.
I was wondering how you came up with the $2500 figure, though. They have the hub to hub axle listed for $1200, and according to the third member section, the differential would be another $250. Add a disc brake conversion for $600, and looks like that comes to $2050. It said shipping is +/- $150 for axle assemblies.
Just be careful dealing with those crooks.
I think @Stumpalama has a thread on this also(?)
forum.ih8mud.com
When I talked to them before I build my axle it was going to be about $2500 and then shipping to Wyoming would have been $450 to my house. My H55F and split transfer case were shipped to SLC and I had to make a 10 hour drive to pick it up. There is a trucking company in town that covers the State that it could have been transferred to. So now when I order a heavy assembly I ask if they can ship it to my home or at least to the depot in town. Shipping has become a big factor for me.Holy Cow! Cruiser Parts has everything! Thanks for the info! It might be worth my time just to buy one from them.
I am not using stock flanged axle full floating axle shafts. I am using after market double spline axles with drive flanges on the hubs. I also installed seal holders in the spindels with a lip seal to run the bearings in grease as they do on the front axle. The drive flanges are supposed to be more waterproof than conventional drive flanges.Holy Cow! Cruiser Parts has everything! Thanks for the info! It might be worth my time just to buy one from them.
If you build a full floater, you retain the rear differential removable differential cover.Thanks for the warning and the info!
You would have to have different drive flanges made or have the splines cut for the differential and the hub. I don't think it would be really cost effective.Ruff Stuffs are for a FF conv not just to put discs on. IMO if doing this you have to get custom 4340 axles made and use drive flanges not hubs. Made outa 4340 the 30 spline will be fine. Or if you really wanna improve it then build a 35 spline center section and have your custom axles made with chromo, 35 both ends. Not sure if the hubs can fit a 35 spline shaft.
Same, but one time I saw a car run into a bouncing, spinning wheel with an attached axle shaft that had come out of a truck's rear axle. I assume the axle broke or the c-clip that retains the axle in the diff failed. That's when I thought that a full floater was a pretty good idea....
I'm not a hardcore rock guy but haven't ever had an issue breaking a semi float axle shaft.
