Hi to all,
It's time to do a "roof off" overhaul.
There are a number of reasons for this.
- The headliner is coming down
- I have at least 9 leaks inside the cab
- The PO did a lousy job and used 3/16" POP rivets
- The BONDO in the gutters is cracking
Here are some pics
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00481.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00481.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00481.jpg"]
[/URL][/URL][/URL]
The headliner is coming down.
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00484.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00484.jpg"]
[/URL][/URL]
The foam is falling apart.
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00500.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00500.jpg"]
[/URL][/URL]
Keeping it up with bamboo sticks.
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC06326.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC06326.jpg"]
[/URL][/URL]
Nice huh?
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC06327.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC06327.jpg"]
[/URL][/URL]
The POP rivets are pushing the wheather strip down causing leaks into the cab.
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00621.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00621.jpg"]
[/URL][/URL]
The BONDO is cracking up causing the water to flow to the inside of the gutter where the headliner is soaking it up.
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00575.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00575.jpg"]
[/URL][/URL]
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00577.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00577.jpg"]
[/URL][/URL]
The PO lost a good amount of the bolts and nuts (M6) and replaced them with 1/4" x 3/4" and some 1/4" x 1" as you can see.
So, yesterday I took the roof of after cutting and drilling some bolts out.
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00606.jpg"]
[/URL]
[URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00612.jpg"]
[/URL]
The
is helping out.
Let the repairs begin!
I made a temp roof with a green tarp in the garden so I can work on it in the shade and also because the "green season" is about to begin.
Here is where I run into the first problem.
I drilled out some of the old POP rivets, made a support rebar with a nice hole/cup in it to save the head of the new rivets and then I started to have second thoughts.
Does the rivet go upside down, so the head is vissible from the bottom or goes the head on the fiber glass side like somebody in an other thread said when I was checking as much as possible threads about this subject.
Checking a pic on the CCOT website revealed that the rivets goes in from the bottom. Or upside down so to say.
So the question for today is: Head up or head down?
I think upside down but I like some confirmation before I start hammering tomorrow.
Rudi
Here are some pics
[/URL][/URL][/URL]The headliner is coming down.
[/URL][/URL]The foam is falling apart.
[/URL][/URL]Keeping it up with bamboo sticks.
[/URL][/URL]Nice huh?
[/URL][/URL]The POP rivets are pushing the wheather strip down causing leaks into the cab.
[/URL][/URL]The BONDO is cracking up causing the water to flow to the inside of the gutter where the headliner is soaking it up.
[/URL][/URL][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00577.jpg"][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00577.jpg"]
[/URL][/URL]The PO lost a good amount of the bolts and nuts (M6) and replaced them with 1/4" x 3/4" and some 1/4" x 1" as you can see.
[/URL][URL="http://i1112.photobucket.com/albums/k490/ruud_coco/Toyota%2040%20series%20roof/DSC00612.jpg"]
[/URL]The
is helping out.
Rudi
