Build rocks and rolls
weekend updates late april
built a hood for the upper shock mounts to stiffen it up, but again it was totally unnecessary. I am my own worst enemy.
full drop. The tie rod and panhard are well aligned
Poly performance limiting straps. Drilled and tapped scab mplates on the frame and then used an existing bolt on the lower links
diff view limiting straps both sides
full drop and passenger turn.
at full drop the springs get into the steering arms. After some slight grinding and adjustment of steering stops its all good.
I might have to change the axle shock mounts a bit by making them taller to avoid rubbing and utilize the most out travel out the shock.
Here are the heater valve pics
I took some pics of the heater valve. It resides above the back end of the engine.
Pic 1 shows the new, straight, water outlet nipple. I wanted a 45 degree one, but couldn't find one.
Pic 2 shows the valve in place. Note the cable loops around and goes through the firewall just below the valve. I mounted the cable in the dash. You can hardly tell it doesn't belong.
Pic 3 shows a close up of the valve. You can see where the cable goes through the firewall a little better.
Steve
