Rivet Squeezer
Georgia
Anyone ever tried one of these? Thought it might be worth it since I'll be putting 2 tops together.
Hand Rivet Squeezer Kit 3" Reach w/ 6 Rivet Sets ***New***
thoughts?
Yes, as a former aircraft mechanic I used that type of rivet squeezer all the time.
Just make sure the throat is deep enough for what you are doing.
I believe it should work perfect for a hardtop rain gutter.
Also, make sure it comes with the right size rivet set.
5/32 x 3/8 brazier head aluminum rivets are perfect. That rivet squeezing tool is incredible. I put two tops together in about 3 hours!
That looks great.
I need to do mine, the PO used pop rivets, and the top needs to be refinished.
So whats the best top finish paint ir gelcoat being its fiberglass? Paint the steel first the put
A gelcoat on the top then seam seal then pop rivet? Whats the best way to do it?
It's already gelcoated. No need to apply more unless there's some damage. Here's what I do:
1) Properly prep drip rail and fiberglass
2) coat with epoxy primer
3) rivet assembly together.
4) do any bodywork that needs to be done
5) apply surfacer primer
6) block it straight
7) repeat steps 5&6 as needed
8) paint
Here is what it looks like when you do like splangly said. Mine needed a lot of #4! I put a coat of 3m self leveling sealer on the drip rail prior to paint to seal the rivets.
Doh! Forgot the seam sealer in my list!
