- Joined
- Jan 27, 2016
- Threads
- 11
- Messages
- 106
- Location
- St. George, UT
- Website
- americanadventurelab.com
When I bought my 60 it had an exhaust leak. I was able to quickly identify that it was leaking at the connection between the manifold and exhaust pipe flange. No big deal, I thought. After me swapping two gaskets and taking it to a local muffler shop (a good one), it turns out that there are several leaks throughout the manifold and it's surfaces, as with a lot of the 60's.
I have read through a lot of threads here (using the search) about headers and manifolds, but I haven't seen one specifically talking about the pros and cons, or at least not one in the last few years.
The exhaust guy was pretty adamant that I go back with another manifold, but my concern is that if I buy another one, I will have the same problems, sooner rather than later even I if machine the surfaces and do everything correctly during the install.
I would much rather go with a header, but I'm not experienced in this engine well enough to know the answer to that yet.
I do plan on doing an engine swap at some point in the future, so doing nothing is a possible option as well.
Thoughts?
Thoughts?
