I have a low mileage fully built white locked 80 series with a Safari Turbo system (not my CampTeq80). The question is should I keep the turbo with the Land Cruiser of sell it separately? The Safari turbo set up sold for ~$7500 USD back in the day and would be considered rare today by many. Having owned a SC 80 this is well above the SC in terms of driveability and performance. Smooth and powerful is my best description.
Everything was replaced (including turbo) or rebuilt less than 20K ago
CARB certified 52 state
3" exhaust
Safari A to A Intercooler
Safari trans cooler
Was installed originally in 1997 making it a super solid system that works without any mysteries or questions going forward. I have all original paperwork, parts list, and installation guide.
Here is what LCOOL said about the Safari Turbo System -
Now this is an impressive kit! With turbocharger and intercooler, a reliable 240KW (321hp)of power and 540NM (398ftlb) of torque makes the 80 feel 1,000kg lighter with around 7 sec 0-100kph acceleration (6.7 sec claimed) and nearly 2 seconds faster than the newly introduced 100 Series V8. The figures however don't do justice to just how driveable the car is. After spending some time in an automatic version on road and off highway at our club property, it's a kit that works very well indeed. You can trickle over technical stuff and accelerate smoothly without any nasty hit as the turbo comes in. It's also one our US members who have to endure anemic performance at high altitudes would appreciate.
The kit is quite comprehensive and as a consequence fairly expensive, however the quality of components and workmanship of this Safari kit is very impressive indeed.
An additional injection management unit is used to meter the amount of fuel injected via a dedicated injector in the inlet tract. The factory ECU and injectors are left untouched. A problem common with turbocharged gasoline engines is pinging or detonation. Whilst this kit does a good job of keeping detonation to a minimum it can occur when using regular unleaded. As a safeguard, the factory knock sensors are retained to retard the ignition timing if 6 successive detonations are monitored.
There aren't a great number of these on the road in Australia and only one in our group. There is however a great deal of interest and we're waiting for more of us to take the plunge.
What would you do?
3" exhaust
Safari trans cooler
What would you do?
