All,
I rebuilt my 77' Aisan Carb for a 2f motor a few months back and during the rebuild I found the accelerator pump retainer peened shut, I carefully filed out the peening to free it up. Overall the 40 ran pretty well after the overhaul. However, about a month ago it refused to idle and would stall. I replaced the carb idle solenoid and the problem went away... for a few weeks. The gound for the idle solenoid is good and I can hear it operate when I turn of the 40.
Anyways...
Now if the RPM gets anywhere near 1000, the engine wants to die. At 1500 rpm it will run perfect, but seems rich. I have tried everything to figure it out and no dice. To top it off, I adjusted the fast idle to 1500 rpm with half choke. The next time I start it, the engine runs at 2000 rpm with the same choke setting. Overall the engine rpm doesn't ever seem to stay consistent, always wandering about 200 rpm. I'm getting super frustrated because I can't seen to keep it running long enough to make any more adjustments.
FYI- The fuel in the bowl indicates dead center of the sight glass.
What could the problem be? As of right now I'm about to give up and buy a trollhole carb and call it a day.
Anyways...
