I'm curious as to what leaks people are getting. The rebuild kit comes with new piston seals. Unless the side of the pistons are totally chewed up, nothing else can leak.
Most don't opt for new pistons and they can get pretty bad.
Mine leaked with just static pressure. I ruled out the piston and seal by swapping them around to see what was leaking.
By the looks of the seal groove in the caliper, it was heavily corroded and when it got blasted it removed enough material that the seal didn't have enough support to seal that area anymore.
The piston slid in far easier than the others did, almost no resistance. The others I used an arbor press to install them.
I should have just tossed em when I resorted to this to get the pistons out.
