Rebuild or Replace - Brake Calipers
i bought napa re-mans after trying to rebuild with oem kit...seized and marred pistons..work good enuff i guess . i cannot recommend auto zone.
steel brake lines from slee ,they work fine.... my 2 cents
Any particular reason you didn't like the autozone ones?
I'm running their gold pads because of the lifetime warranty (yes you read that right) and same compound type as OEM.
Can you still get reman calipers from toyota? There is a part number for them and I bought two front calipers from toyota back in probably 2012.
I checked maybe 1 or 2 months ago and they were on a significant national back order.
i was referencing calipers as the subject of my first point-
as far as pads tho ,i run the ebc pads and they are great-
After spending a small fortune on Brakleen over the years, I found that denatured alcohol works better for cleaning everything covered in brake dust, and is much cheaper.
I like a 1/2 drive breaker bar and a 2-ft length of black iron pipe to loosen the caliper mounting bolts (my air impact won't fit in there) if anyone but me has installed them. For some reason, the prevailing wisdom seems to be that you cannot torque caliper mounting bolts or lugnuts too much.
I have taken to comparing the inner and outer pads before I remove the calipers, so that I know whether the calipers have been sticking on the pins. If your replacement kit for the pads/calipers comes with pins, throw the old ones away. If you keep them, they should be polished, but don't go crazy on them; they need to be loose but not sloppy, or the calipers will bind.
Toyota says to throw the mounting bolts away too. At 76-ft·lbs, I have a hard time disagreeing with them. At somewhere over 100-ft·lbs, which seems to be the prevailing installation torque, I definitely agree with them.
Thanks. How much fluid am I going to lose doing this? If I just allow the lines to drain into the container I use for old oil, and then refill the system will I regret that?
My experience with auto zone.
Im an instructor at a trade school. We have auto zone as a sponsor (yea i know). ALL the brake parts I have been forced to use on our training vehicles failed quickly. Master cylinders, calipers, combo valves... leaking after as short as a month. These are not taken apart by the students.
Then you have the feedback from the students. same across the board.
I don't want to come off sounding mean but, the compound they use on their pads is not even close to oem. Yes you can get ceramic and metallic.
The comparison is more like, I bought a set of two dollar boots. Their the same as one hundred dollar Danners because their both boots.
I know some people like them and their cheap with a lifetime warranty. Personally I need all the stopping power I can get from running 35's and I wont get that from those. I use stop tech commercial metallics. If I ran them against an auto zone rotor, I would destroy the rotor due to the lack of nickel and low grade iron.
Glad to hear some first hand experience with a large sample size.
The OEM pads are supposed to be semi-metallic or even organic for these trucks AFAIK? This was the 90s, before a lot of the fancy compounds got common in your average vehicle. Of course, there is a HUGE variance in semi-metallics, or even organics. There are some shockingly high performance organics in the mountain biking world, and they deal with higher temps than us.
The autozone gold pads are DOT FE rated, that is, they can lose up to 44% of their braking performance at 600F. In my case, I use the engine for braking on long descents and I don't tow heavy stuff so that doesn't matter to me.
I suspect the pads that came with my rotors were GG rated, (barely took any pedal to skid the tires on brand new ST/maxx's, and had no fade even on the grapevine's downhill), but they only lasted 7k miles so not terribly practical if you drive very much. I expect I'll get a lot more life out of these, but even if I don't its not a big deal cause of the warranty.
Maybe 2-3 oz; I plug my lines so I don't loose much.
Prepare to take the car off the road and allow time in case it is needed to get parts. Pull the pistons and check the bores, let their condition guide you whether to replace or repair. If the brake fluid has been changed regularly there will be no corrosion, if you see any then rename the calipers doors stops.
As for painting everyone to their own, but if you are going to use the old calipers then pop them in the machine shop and ask if they will drop them in the hot tank for you.
regards
Dave
