Rear Tailgate Storage Solution - The $55 version
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
This mod is gaining popularity so here is my set up and install
Ebay purchase at $54.95 linked below
TEMPRESS 44203 GRAY 12 5/8 X 8 3/4 INCH POLYPROPYLENE BOAT ACCESS HATCH
My criteria - although different from some
Ability to open and close with one hand - slam latch
Strength I need to stand on my gate regularly to close my CampTeq - If anything my gate is now stronger
Not required to remove everything off my gate to open - big problem IMO with larger set ups
Ability to close my tailgate - with my storage rack I was challenged with clearance requirements. I needed to spent extra (way too much) time to recess the hatch for the needed clearance. (see pic) This was the thinnest hatch I could find. Quality is first class and slam latch is replaceable.
Installed closed
Installed open
My cooking prep set up
How it started - Lay out was done to maximize usable space and allow all snap in fasteners to be used. The center section does not offer much in the storage department and I didnt want to compromise the latch mechanism. With my storage rack once my tailgate is close gaining access to the latch mechanism is almost impossible. Who would of thought removing a rod would make the gate not open. :doh:At least I figured it out with everything open and accessible.
Once the hole was cut I found the latch rod going through the new opening. I bent the rod to have full clearance of the opening but it required lengthen of the rod to make it all work. I also shimmed up the voids in the panel where the hatch mounted for the strongest fit.
I wanted to block off stuff sliding over to the non accessible side. I had spent better part of the day on this install so I opted for a semi ghetto stacking and glueing of light weight foam.
The biggest time consumer was recessing the hatch as deep as possible. The hardboard underside was cut 1/4" larger then the overall hatch leaving 1" of the carpet in place for a clean finish. Getting everything to line up was where I wasted all my time. But Im very happy with the end results and my time wasted will be forgotten.
Why didn't I think of this sooner. Will the hatch hold the weight of a person standing on it?
Down side is you can't see/use the entire area of the tail gate, and it's not shiny :flipoff2:
Needing to move everything off the tailgate to gain access did'nt make sense....for me:flipoff2:
Easily no deflection at all. Partly because all factory bracing was in tack. If you go full size you loose that. Could be a concern on a full size depending on your use.
Dang, why can't I see the pics??????
NLXTACY congratulations on breaking 12,000 posts! I've learned a lot from your threads and appreciate your methodical approach.
J
X2 ^
Also, like this mod, looks like one I'll do.
