Rear shock mount bending
Unless I can’t see it, you need a really large washer on that bolt to keep the shock bushing in place.
Good catch. Will add in AM. Thanks
At this time, I would clean off your lower control arms and inspect for any rust. If there is any address it and paint the control arm.
@Tex68w drilled some holes in his to allow for some drainage.
No rust on LCA’s, they were slick and greasy, just covered in dirt.
I apply an undercoating every fall to prevent rust on East coast. Downside is it collects dirt and mud but doesn’t seem to trap moisture which is a good thing.
I did and it worked well.
Question to the bent lower shock mount folks w/ BP51/BB shock guard issues: Has anyone seen/done a replacement sleeve/stud installation? (or know of a link to such a procedure) Basically replace the OEM one with a new one? My interior threads got super chewed up; not pretty and no longer a smooth threading for the bolt. I've done the bend-back process once before, using a longer interior bolt (little by little) and external sleeve to straighten out...but threads are not doing well. I'd rather not have to replace the whole assembly.
