Jason of 'Cruisin Off Road makes some as well. I have them on my 80 and so far so good with the beatings.
you can buy the set of used stock LCA's from yjeff here on the board (just took them off - in good condition) and cut and weld in a stonger outside piece of pipe like mentioned in the posts above. Its sucha close fit I would imagine you would be better off with some straight ones to start off with.
On the "lumpy forever mesa drive" run in the holiday binge wheeling, he mangled one of the rear sway bar brackets. Got a pair of replacements from Rock Auto, lengthened them good to go. Look to be good pieces, priced right.![]()
Mine have seen better days, how much?
...and I thought Slee's were pricey. And I don't know about that angle, it seems to me a straight line would be better for rock surfing which is pretty much what I'm doing in an 80 with a 4" and 315s.
I wouldn't run the bent ones, have seen them get a couple of rigs hung up. The straight arms ramp up the rock, feeding the rock to the tire. The bent ones do alright in the straight area, when it gets to the bend, cant pull the angle, so hangs on the angle/axle tube, they don't lift the tire like straight arms do.
... He got new bushings, so it's end to end.
I'll bring them to the meet tonight if anyone is interested? Thanksyou can buy the set of used stock LCA's from yjeff here on the board (just took them off - in good condition) and cut and weld in a stonger outside piece of pipe like mentioned in the posts above. Its sucha close fit I would imagine you would be better off with some straight ones to start off with.
If your in the Phx area industrial metal supply is my go to. Edit: I have also had good luck with sun valley metal supply.Bumping this old thread up to top. What vendor is selling these DOM tubings for a decent price? Ruffstuff has a 4' piece for $50+$24 shipping to my place. This is 0.25" wall thickness, a little thicker than what the first post in this thread.
RuffStuff Specialties: Basket Contents
RuffStuff Specialties manufactures top-quality off-road parts for 4x4s. Explore suspension kits, steering kits, disc brake conversion kits, bumpers and more.www.ruffstuffspecialties.com
