rear brake pads....does it really matter?
I am a avid "OEM only" kind of guy. I think it is time for a set of rear pads. Beno is on the road for a few weeks and the local dealer is out of stock and is almost 3 hours away. I will be in town tomorrow and could swing into a few different auto parts stores. Would there really be anything wrong with using a run of the mill "name brand" brake pad in the rear? Any suggestions to avoid or get? I don't drive this thing fast. I just need reliable predictable pads that don't eat rotors.
I usually go oem as well, but last "brake job" I used NAPA reman calipers/new rotors and their "best" pads, so far so good
I have run Napa up front, EBC Green Stuff, OEM and elcheapo Carquest in the rears. Except for the Green Stuff, all the rest seamed to be equal in braking. Green Stuff = better breaking.
When I was running Carquest in the front and with LSPV removed and with no portioning valve I ran Green Stuff to equal out the braking. After installing the portioning I had too much rear braking.
If you have OEM in front, Napa mid or better grade might be a good choice.
I installed EBC green stuffs in the rear first and could tell an immediate improvement over the Akebono ceramics they replaced. After a couple of weeks, I finally got around to replacing the fronts as well. I love this combination except for the first stop if their cold. The first stop always requires a little more effort but they are good to go after that.
Napa premium pads with life time warranty is the way go, just go back with old pads to Napa and get new one. Given how fast the 80 eats pads that's the only way to go.
Given how easy it is to replace the REAR discs, I would put in there a known brand and call it good. If the discs are screwed in a few years time, they are a simple unbolt/bolt on job.
Go with what you can get.
regards
Dave
My 80 has a set of EBC Greenstuff pads on the rear brakes that have lasted a very long time, maybe ? 100,000 miles, I've forgotten it's been that long. One pad on one side is just now getting worn out. Truck's not lifted so the proportioning valve should still be set correctly. They seem to be good pads.
I have 100 series Toyota pads up front, also long lasting, 50,000 miles and plenty of life left on them.
A bit off topic but FWIW: I swapped my front pads (after maybe 25,000 miles of use) side-to-side a few years ago as an experiment of sorts. Swapped each pair of pads first right to left, left to right, but also swapped pad positions; what was the inner pad went to the outer position and vice versa. I know, not standard practice, but the pads were wearing unevenly a bit and I said Meh, if it doesn't work I'll just get new pads. It's been about three years and I've had no problems with the front brakes after rotating the pads, truck stops straight ahead every time I push on the pedal. FWIW.
if your pads are wearing uneven your calipers are not working properly. Most likely they need to be rebuilt. Use Sil glyde on the pins....
Most brake pads are pretty much the same. I doubt you will tell a difference between oem and aftermarket in stopping performance. In aftermarket you have a few options-metallic, semi metallic, and ceramic. Metallic will last longest but at the expense of eating into the rotors thus you may not be able to have the rotors machined the next brake job due to the pads eating too much of the rotor. Ceramic pads eat the rotor the least amount and are quietest but at the expense of they wear the fastest. I typically try to got ceramic pads. Whats most important is replacing the boots on the rear calipers and installing new hardware and lubing the slide pins and hardware where the pads contact the caliper bracket. This will ensure even pad wear and proper braking and keep the pads from sticking.
I thought this too until I tried the EBC green pads. I noticed a huge increase in braking "bite" right off the bat. The stock OEM pads I did not like as they would not bite like I wanted them to.
Just as a FYI thing, I recently put in Powerstop rotors and pads all around and it stops better than before, on last three years of stock brakes.
1973 Guppie: I actually mis-remembered, it was one side of one front rotor that was not wearing evenly as the reason I swapped the pads around. DBA was telling me the pads were the reason for the uneven wear, but it never made sense to me. Not enough sleep when I wrote that, sleepy minds are unreliable. Either way, guess the point I was trying to make is that you can swap pads, not that you would normally do that.
I had the napa thermoquiet (?) and they wore quick. I run Hawk now and they have lasted but I don't put many miles on. I run Hawk HPS on my other two cars and they stop great,and have lasted almost 100k miles on my Camaro which includes racing.
No, I don't think it matters.....if you get them at Oreillys with a lifetime warranty which includes normal wear. I haven't paid for a set of front or rear pads in 10+years with all four Lexii. They wear, take them back, get new ones. Why have it any other way?
How worn do they need to be before they will warranty them out?
I replace when I notice my brake fluid getting low and when I begin to hear the expected noise. It is more difficult and takes longer to get the trucked jacked and tires on and off than it does to replace pads. Can't imagine paying for pads as often as they wear.....when you don't have to.
