I searched and it appears that many people recommend installing two shut off valves under the hood on the the heater supply and return hoses, to prevent the heater from heating the inside every time you drive the 40.
Is there a problem with circulation with just shutting off the two hoses? Would it be better to fab up some sort of manifold between them so the water would circulate in two paths.
1. during cold times water goes from the water pump through heater then back to the head.
2. during warm times water will go through the water pump then return to the head.
Or is this a solution to a problem that doesn't exist?
