Yesterday I came across a thread where the poster was showing cracks that had developed in a RD radiator with 100k miles on it. A bit of a turn off considering the cost of a RD unit. But before I saw that thread I ordered a new OEM radiator for my currently happening turbo charged build with rebuilt 1fz and A343. The radiator in my previous 80, which I flopped and ended up parting out/scrapping out, was also OEM purchased in 2019 and ran approx 3.5 years. Was planning to reuse it but decided a new engine deserves a new radiator. I don’t have the variety of experience with radiators as some of you do but I can tell you that going from a CSF 2517 copper core brass tank radiator to the OEM AL made a considerable difference in my coolant temps especially during summer.
After hearing about
@Marco Lau ‘s experience where his fan ate the thicker RD radiator I was gun shy about spending the greenbacks on a RD. I’m not sure that there is another all AL radiator other than RD that isn’t manufactured outside of China so there’s that.
I have no doubts about an OEM AL radiators ability to keep my turbo charged engine temp within normal perameters. Copper absorbs heat more quickly than AL but AL releases heat more quickly than copper. And remember that all that solder used to build a copper core is a pore conductor of heat. 100% of an AL core is transferring heat. It’s probably true that auto manufacturers switched to AL because it’s lighter and in some cases cheaper especially with plastic tanks but with the track record that the original radiators have for reliability and longevity I see no reason why not to run one. Perhaps Toyota went with a thinner AL core on the premis of being able to pull more air volume through it in a given amount of time?
The plastic tanks can be removed with a pliers type tool and the gasket can be replaced. However, an OEM rad that’s ten years old and has leaking gaskets like the one previously posted may not be a good candidate for gasket replacement. Ten years is a pretty good run, I agree that 20 would be better.
Some members here who live in the USA’s hottest area have boasted about the Chinese made TYC for cooling better than OEM but no one ever does a long term review of these products from overseas. They say it doesn’t matter if they have to replace the radiator more often because they are so cheap. Ok…..
The vendor from whom I purchased my turbo kit ran the same kit on his own high mileage 80 with stock radiator for 18 months or so as his test mule. He reports coolant temps that were always under control. That’s good enough for me.
But will I run red, pink, yellow, or green coolant???? The decisions are many!
