Awesome to hear... Give us a follow up report in a few weeks!I am happy to report the vibration was cured by replacing the rear prop shaft.
Will do. I am hoping to head out for a day of mild wheeling this SundayAwesome to hear... Give us a follow up report in a few weeks!
Even before I finished reading the whole post (which by the way was excellent in laying out the details!) I started typing up that you might need the "flux capacitor"/ frame weight thingy.Aaaaaand I'm back. I've managed to get my driveline vibe basically eliminated - as @abuck99 suggested, I shortened the lower links to minimum, and that seems to have mostly sorted my u-joint vibes. It has not, however, done anything for my cyclic highway vibration. Just to recap -
List of replaced parts:
- U-joint/driveline alignment vibration - mostly constant high-pitch buzzing, accentuated by heavy acceleration or deceleration, anything that increases the loads on the driveline. I induced this type of vibration on thing on my quest to eliminate my other vibration, but have dialed it back out with my adjustable lower links.
- ???/other vibration, similar to wheel balance or worn shocks: cyclical vibration that comes and goes in 10 second (ish) cycles when cruising between 70 and 80 mph. Feels like a wheel balance thing, but have had them repeatedly balanced and rotated and never changes. Not super intrusive but noticeable, sometimes more so than others.
Related modifications/parts:
- Front CVs and drive flanges
- Front wheel bearings
- Front and rear prop shafts (and re-balanced rear)
- Brake rotors all around
- Two new calipers to replace sticky ones - one front, one rear
- AHC lift with AHC spacers
- King rear AHC springs
- Cranked T-bars
- 33" All-terrain tires
- Rear poly spring spacers
- AHC has been flushed/bled/is in spec pressure front/rear
So, that's where I'm at. So far I've just had to live with it, but it's annoying that even my old rust-bucket tacoma doesn't have a highway vibration like my 100 does.
I guess a few more questions:
- Does anyone have a frame weight I can borrow/have/buy to test that? I've definitely not got one on my frame. I can post in the classifieds I suppose.
- Maybe an axle bearing problem?
- Engine/trans mounts? The vibration feels slow, tho, like wheels, not like engine or driveline. Trans mount looks fine but is also really easy to replace.
One other thing you could try (please be safe and not try it going up hill or when other traffic is on the road or when you have passengers, etc. etc.) - going at a speed where you feel these vibrations - shift into neutral - that would remove driving force from the drivetrain and see if the vibrations are still there.
If you had access to a closed circuit long straight stretch I would even recommend going into neutral and turning the engine off (but keeping the ignition at position 1 to avoid steering lock) and see if that eliminates the vibrations. But I don't think it would be safe on public roads.
| 9052025039 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.29,MARK 1 | 8 |
| 9052025040 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.31,MARK 2 | 8 |
| 9052025041 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.33,NO MARK | 8 |
| 9052025042 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.35,BROWN | 8 |
| 9052025043 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.37,BLUE | 8 |
| 9052025044 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.39,MARK 6 | 8 |
| 9052025045 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.41,MARK 7 | 8 |
| 9052025046 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.43,MARK 8 | 8 |
| 9052025047 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.45,MARK 9 | 8 |
| 9052025048 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.47,MARK 10 | 8 |
| 9052025049 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.49,MARK A | 8 |
| 9052025050 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.51,MARK B | 8 |
| 9052025051 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.53,MARK C | 8 |
| 9052025052 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.55,MARK D | 8 |
| 9052025053 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.57,MARK E | 8 |
| 9052025054 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.19,MARK D | 8 |
| 9052025055 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.21,MARK E | 8 |
| 9052025056 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.23,MARK F | 8 |
| 9052025057 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.25,MARK G | 8 |
| 9052025058 | RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) | UZJ100 T=2.27,MARK H | 8 |
See I thought the same thing: u-joints. I was also concerned about the teeth in the split joint being worn and allowing some play so I ordered a new driveshaft from the dealer: new joints already installed. No difference.snap ring for rear joint list. Could be same as front But I didn't' check. year of 100 from 8/2002 to 2007 is the same so year doesn't matter. Might want to check pre 2002, I didn't.
DOn't know how I'd have enough of these to mix and match a proper install. maybe guess 4 sets of 4 clips of 4 sizes.
I'm also working on a growl at 70mph under load that vanishes unloaded. New joints 1.5 years ago OEM. But didn't realize the snap ring importance.
Easy version, in order. unlike parts pages.
9052025039 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.29,MARK 1 89052025040 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.31,MARK 2 89052025041 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.33,NO MARK 89052025042 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.35,BROWN 89052025043 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.37,BLUE 89052025044 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.39,MARK 6 89052025045 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.41,MARK 7 89052025046 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.43,MARK 8 89052025047 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.45,MARK 9 89052025048 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.47,MARK 10 89052025049 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.49,MARK A 89052025050 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.51,MARK B 89052025051 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.53,MARK C 89052025052 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.55,MARK D 89052025053 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.57,MARK E 89052025054 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.19,MARK D 89052025055 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.21,MARK E 89052025056 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.23,MARK F 89052025057 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.25,MARK G 89052025058 RING, SNAP (FOR REAR PROPELLER SHAFT JOINT SPIDER BEARING) UZJ100 T=2.27,MARK H 8
Feel it in steering wheel? Seat?
Floorboard?
Start with the tires- ideally if you could swap out to another set of A/T already mounted to test back to back.
Toyo open country MT: how many miles on the tires? Regularly rotated 3-5k interval?
Fwiw fantastic tire offroad- but once these tires are cupped- they ride like absolute shyte -especially low speed- dont balance well- and transmit heaps of vibrations. This was my experience on my FJC.
Metal Tech bolt on sliders are solid and no contact with frame or body. No flux capacitor either....I guess that was removed many moons ago. How heavy is it? With all of the other weight added to the truck, curious how that would play into it. I need some of my dynamic modeling bubba's at work to develop an ANSYS model for our trucks! I will inquire!!If you have sliders, make sure the mounting brackets aren't touching the floorboard, if they are, loosen them and lower them a little. Also, did you have to remove the flux capacitor when you installed your skids? If so, put it back if your able to to see if that helps.
I have a video...assume I can't post those here. Maybe I can link to youtube or somethingI was thinking you were running the M/T- the A/T II outer tread block wont cup and vibe the truck like the M/T
