prototyping an 80 front
lcwizard
Supporting Vendor
Supporting Vendor
Miami, Arizona
Website
www.4plusproducts.com
We are presently prototyping an 80 front. Here's the three week process in a brief slideshow.
This first is a more aggressive design. We will be posting a less aggressive, lower profile look in the coming weeks. Some features include three mounting positions for the winch to help with winch offsets.
Because the 80 series is very narrow between the rails winch space is limited to the 25.5 " between frame rails. We wanted to keep the winch between the rails, as low as possible, for the strongest possible
design. Built in 1/2" quick connects on the bottom for snatch straps and ropes.
1/2" side mount plates and 1/4 top and bottom mounts, for 7 total attachment points per side
Fj80front Slideshow by Dave Gore
Looks very nice. A few comments.
1. Side wings look low compared to body.
2. Add 1" thick shackle mounts to front. I'm not keen on looking for attachments points that could be under mud, snow or water.
3. Tabs for mounting aux lights and antennas.
4. Personally, I like the ARB high mounted bush bar for pushing against light vegetation.
5. Personally, I'm not sure I would like to work on the engine with the amount the upper bar protrudes.
Nevertheless, it looks like it has been very well thought out, and quality appears to be top notch so far. Good luck!
It's cool to have a different look, very aggressive.
Think high profile as possible though.
@canman
The body of the 80 does curve up in a smile so a straight top on the bumper makes the gap at the wings greater than at the center. ]
The #2 point is already addressed . the 1 3/8" holes in the 1/2" plate get a 1 3/8" x .188 wall tube that is ]
1.125 " long welded in like all our 60 and 40 bumpers.
Mounting for lights ( up to a 20" lightbar ) will be on the low cross tube on this version ,and there is a step in the center channel of the low version that will have room for a 20" light bar.
I do like ARB designs also but there is also an entry on the market for that..., ARB. I try not to knock off other designs overtly. Slee and Luke also have nice designs. It would be simpler to copy but that does
no one any good and doesn't add choices to the market
The bullbar section is just a little too overdone for my tastes. I absolutely loved the simple design of my 4+ bumper on the 62. I know the body lines are all different, but I would prefer something simpler. Just my $.02
img_0002-jpg.908826
Mad props on asking for feedback. :)Leave the center main winch and bolt to frame part alone part alone, move the wings up level with the turn signals and the flares-even just cutting the wings off of the main part and just moving it all up 2 inches might look fine. The tubing doesn't work for me and I would make it removable so that people could have a choice to go with tubing or just have the main bumper. Here are some tube designs that I personally like....
Google Image Result for https://www.hansonoffroad.com/prodimages/JKSL1402-P1_medium.jpg
Google Image Result for http://www.americanfourwheeler.com/images/D/JK-Front-D10-400-01-01-01.jpg
Google Image Result for http://image.fourwheeler.com/f/18790632%2Bw600%2Bcr1/129_0210_01_z%252Bttc_1973_ford_bronco%252Bfront_side_view.jpg
I like the beefy tube work. I especially like that it is different from other bumper offerings.
I expect the price of your bumper will be double or triple my current personal favorite front bumper (Bump It Offroad's tube bumper), which also happens to be among the least expensive options. (Pretty please make me wrong, and make your bumper cheaper than an ARB....)
I like the center section leave it as is but the wings need to hug the body line a little closer. Other that that great looking bumper.
Good looking prototype. Ditto what 97CruiserJoe said, I like the wings but a more snug to the body fit all the way to the fender flares on each side would be more aesthetically appealing. The Bullbar protruding has too much underbite and doesn't match the lines of the bumper. The winch should have a removable cover to protect from elements. The 1/2" quick connects at the bottom could be removed. This is great stuff and thank you for allowing us to publicly critique the bumper, you do great work, I hope you improve the bumper in the best way you see fit.
Thank you,
Zona
@zona , @97CruiserJoe
The wing issue was apparent right away. We've already figure a fix without misaligning the center and wings. The upward gentle curvre of the 80 body from center to the outside ends just adds an extra consideration.
@Blade 80LC and @White Stripe
I know there will always be the aggressive vs subdued camps, as far as appearance goes so the two options will be offered.
For those who want zero tube work, that's always been an option on any bumper. We've sold a couple 60 series fronts with no tube work at all
@nuclearlemon
As far as foot down, yes. All the planetaries that recommend foot forward are usually the 12,000 and up winches. The frame rails of an 80 are 25.5" apart making it a challenge to fit many winches. I've seen foot forward recommendations on some of the larger Warns like the M15K and M16.5
but they won't fit this bumper without a custom center section anyway. Center of spool to end of winch body distances are 11" and 14" , with the larger dimension on the driver's side. All the other Warn's with an offset are to the passenger side. To accommodate the most winches we'd need three different front sections. One centered , one with a 1.5" offset to the right and one with the same offset left. Still there would be quite a few winches that just won't fit between the 80 rails.
To make the winch mount foot forward we'd have to go away from the faceted channel and go virtually flat. You would need a flat face at least
6"~7" tall to fit the standard 6" spool planetaries and a face about 10" tall to fit the larger planetaries that have the 9" cable drums .
As it is we will be recommending hawse fairleads with this bumper. The roller leads would hang up first in this design
The bumper itself looks great. I like the lines and fitment (if it can be moved up a bit tighter at the fenders) and the incorporated tow hooks are cool. The forward leaning bulbar isn't my cup of tea, but I'm sure some will like it. Quality looks top notch as usual.
