- Thread starter
- #21
73lndcrsr said:I will see if I can get some pics today. If the weather will cooperate.
Here is a sketch also.
Perfect, thanks!
Cruiserhaven said:9/73 frame, 4" spring lift with flipped rear springs and 1.5" shackle lift. I also have the 4+ kit for 2" body lift.
Interesting idea about the u-bolt plate flip. The ones I am using are aftermarket u-bolt skid plates so they taper in the front to make it easier to slide over rocks so it might defeat the purpose with them.
PabloCruise said:I asked because that is my plan - flip the u-bolt plate when I lift and flip rear springs around. Looks like it will work.
Whose 4" lift did you use?
camcruiser13 said:i moved my shock mounts from the u bolt plate to the axle and the angles changed a bit and can tell no difference in ride or otherwise. got more travel out of it too
camcruiser13 said:im getting a digital for christams and soon i can post pics, sorry pablo
camcruiser13 said:i havent forgotten
