Build Project X
Ok this is probably going to be a rather newbie question, but where did you get that dash piece that goes above the custom gauge panel (with the switches and ac vents). It is the one that has those three longish raised dashes. Or did you make it yourself? Amazing cruiser!
Eli
Eli
The piece above (painted the same color as the truck) is the original dash of the FJ-45, I believe.
It is the original dash assembly. Got the "Pismo" lights mounted and wired to the high beams through a 40A relay. They are some bright sucka's too.
Gary that thing looks great with the old school lights.. Good to know your using it.
Wag, I am doing somthing simliar as you did. (Project Uranus)
I am about 1000 lbs under the stock weight of an 80series I am afriad the slee springs will be too stiff. Hows it been working for you?
P.S. Looks awesome man.
Interesting name.. Project, "ur anus"
