Problems Balancing Tires
Ok I just took advice from a tire guy, who said some of the larger tires have issues and beads are the best BTW all big rigs use beads and have no issues ;)
I had beads in my old Boggers, but you expect it with those.
These BFG radials have to be from a crap batch to not balance on rims they spun up. That’s unacceptable - these had stickers in the pic I saw, so I’d return both sets & start over.
Unless you got these on a “fell off a truck”-deal, then you know why they were there to begin with. Rejected by someone else.
He went though 295's and those 285's and could not get them to, balance, I wounder if the tire guy's have issues with balance or like I have ran into " I get Mud in my tires" a slight amount of dirt stuck on the inside of my wheels the rears more than the front's it is a slight 1/4'- 3/8' from silt like dirt, every time I rotate my tires I scrape the crap off , Oh and I have Beads got a thrown off the truck deal 🤣
@shocktower - I’m with you on beads as a legit way to balance non-radials or even Interco radials, but if it’s a tire you can buy at Discount or similar, that’s messed up.
As for clean rims - I know some swear by clip-on weight, but my wheels always go in clean as he11 so I can foil/furnace tape over the stick-on tape style. Been my “go-to way” for all my hick ‘Yota crap on down to my 18” BBS LM’s /30 series tires on my project car.
Foil keeps the weight from ever flinging loose.
We don’t have “fell off a truck” -deals here, that’s strictly a New York / Jersey thing. ;)
Out West we have “my cousin knows this guy” or the ever popular “meth monkey with sticky fingers via CL” -hookups. :p
But seriously, BFG AT’s should never need beads like it’s Mardi Gras.
Dirty wheels or broken machine, either way something hinky there.
No radial street meats should need teflon beads IMO.
The 285's are new from the factory. I am leaning towards the tire place is not doing a good job. The tires were taken off the rim and did not contain any sort of debris inside. I have an appointment Wednesday for a facility that has road force machine. I will report back what they find. hope it goes well.
I see these are LX wheels, are they on a LX or older 80? The reason I am asking, and I don't know for sure, are the older 80s hub-centric? If not, that may be an issue. I had an issue years ago when I bought wheels for a Honda that were not hub-centric and had a huge problem trying to get them to "balance" finally had to return them and find wheels that were.
Other than that, on vehicle balancing, as suggested above is the best way to go but, you should not have these kinds of problems with BFG tires (or any major manufacturer) unless something is wrong with them or the wheels.
🤣 My friend sells tires and his kid did not like them, and he knew I was having serious Good Year problem and needed tire asap , so he gave me a great deal , The beads I used are glass beads and I stand behind the thinking of the trucking industry, by using beads exclusively.
Please explain, since Big rigs use them with great results, tell me why, while off roading you will never chuck the weights, you ebd up using less weight so please tell me
In 25 years of off-roading with 33 to 35” tires I’ve never been unable to balance my tires. If it’s a quality tire 35” or less which is mounted on a wheel that’s in spec, and connected to a drivetrain in proper working order, the traditional method of balancing a tire will works just fine.
I didn’t realize “tire beads” was a trigger word.
Hey find a safe space for the triggered ones, :rolleyes:
... I stand behind the thinking of the trucking industry, by using beads exclusively.
It's nice that you have something to champion!
Semi truck tires are made with more precision, many don't need much, if any balance weight. Beads, Centramatic, etc, work well, except when they don't. The highest chance of success is on skinny tires, the wider the tire, the lower the chance of them working well. They do a good job on normal radial imbalance, but if there is significant lateral imbalance, not so much. Wider, HD off road tires with thick sidewalls have a much higher chance of lateral imbalance and the beads can't get where needed to do the job.
A relatively small tire like a 33" should not need anything close to a pound of weight. Most likely have a defective tire or installer. If the tire does need that much weight, and they can get it balanced, it's not likely to get better with age, I wouldn't accept it, is likely to become balance proof. A defective installer is easier to replace! :hillbilly:
Well I am all about simple and I have chucked the clip on weights and hate the vibration . So I read a n artical on the lateral inbalance and they said exactly what you said but hey I guess just their own testing means nothing :rolleyes:
New 285’s are balanced via Road Force! Little to no vibration.
I run 10oz of air soft BB's in each tire. No issues. 37x12.5x17 KM3's on raceline beadlocks.
