First off, thank you to everyone on this forum for all the expertise and assistance. This is definitely the best place for 80 series tech. That being said, I'm having problems with my 93 FZJ after resealing the valve cover. Here's what I've done:
New valve cover gasket
New spark plug tube seals
New NGK plugs gapped at .030 (Had Autolites in it)
New non OEM parts store plug wires
New Throttle body gasket
Cap and rotor were done 50 miles ago and had no issues
On restart I'm leaking coolant at the throttle body (new hose clamp tomorrow) More worryingly, it's running rough and/or misfiring with lots of white smoke. To me, it seems like it's running on 5 cylinders. It has no power and stumbles on throttle tip in. I'm really hoping I've got a bad plug wire here as I'm terrified about the head gasket. It drove in to my garage perfectly fine a week ago and there was zero evidence of a HG leak. No consuming of coolant and runs nice and cool with no overheating. No warning lights and good oil pressure. Last month I changed the radiator, all radiator hoses, thermostat, rad cap and put in fresh Toyota red coolant. No issues before or after that (OEM radiator was leaking).
Any thoughts? Bad plug or wire? Coolant not reaching the TPS or IAC causing instability? Injector dropping out? When it's running its stable, but rough. No stalling and no knocking. Was dead smooth before the above work. Thanks in advance.
