Pretty quiet in here... what are you working on?
NGK R BPR5EY II
Did not help acceleration stumbles, have been reading on the cleaning the pcv??? Valve
The ones you pulled out or the ones you installed?
I don't think platinum's are recommended for these engines...
EDIT: I read it somewhere before, but I think it just comes down to the fact that the platinum ones don't improve much in a dizzy engine
Guys,
I'm in the middle of an axle rebuild on my LX450, should I weld the splines and ditch the c-clip this since the axles are out?
Guys,
I martacked my front axles on the front of my FJ40 (before I switched to Long fields) with excellent results.
That being said, I haven't researched doing this on an 80.
My 1st instinct is, why not?
Maybe it has to do with 80's mostly running drive flanges vs lock out hubs? IDK. Is there an external snap ring on the end of a 40/60 birf with lock outs installed?
The snap ring he is referring to is the one inside the birf. All the Martack does is keep the inner shaft from walking too far into the diff, just like the snap ring. It's a pretty simple and ingenious trick. It certainly makes swapping a birf a snap.
40s and 60s never had drive flanges, but if they did, it would be no different than selectable hubs.
So, it looks like it is done on 80s as well. The pic posted is from this thread in the 80 section.
I can detail the process I used to mark my 40 axles, if your interested in doing it.
I get all that. What I'm curious about is how the birf stays fully seated on or walking off the splines of the inner axle shaft without the cir-clip. Does the lock out keep the birf located properly? Or is this irrelevant?
The birf stays in place by the c-clip at the end of the border through the drive flanges. It doesn't move much. The Martack keeps the inner axle from moving too much in or out.
I stumbled across it on the Copper State Cruiser's tech section. I'm now trying to improve the knuckle sealing surface and don't think I'll mess with trying to do any mods this time 'round. I'm anxious to put the thing back together.
Martack Inner Axles
Changed out some weak LED brake lights (Sylvania Zevo 1157R), upgraded the reverse lights to super bright LEDs with a beam lens on 'em and changed out the weak-ass front clearance lights for some 1156 LEDs from Amazon.
And I got a new toy, err tool too!
Swag offroad V3.0 table for my HF portaband. This will make cutting patch sheetmetal pieces and brackets a snap.
I broke the cheap HF blade before finishing the cut.
I need to get a few quality 10 tooth blades for the big stuff.
