Preserving Miss Kitty, circa 1964
Looks the same, same year range as the one in my Mar. 2nd post, which fit the battery tray fine. Different vendor. Zoom in on the business card in that photo if you want to comparatively shop.
Yeah, just had a look and they seem to be the same. Thanks!
So @swamp-thing had a couple early brown inspection lights he was willing to part with and one is on it's way to Miss Kitty.
Miss Kitty still has pinkish old clear coat on her and @RAGINGMATT took the opportunity to share a pic of a a different pinkish Land Cruiser:
This reminded me of the scene from Crocodile Dundee.. "That's not a knife. This is a knife.". That's pink all right. And even a pink Highlift jack.
That is a Awesome First Generation Brown Cord TOKAIRIKA @swamp-thing " Double-Hooked " Miss Kitty up with :popcorn:
I have a JDM Whiskas Treat for Miss K's New Inspection Lamp , in the form of a #1073 NOS OEM Toyota TOSHIBA 12V23W bulb
PM me your shipping info. and i will send it out
I see the light!
The cord is so nicely tied I'm afraid to undo it.
The receptical isn't broken but the plug doesn't want to go in very far. I suspect forcing it is how they get busted. Anyone ever refurbish one and have advice?
I see the light!
There are a couple of versions of the early, brown-cord inspection lamp. The plug on the early version appears to have shorter prongs than the later plug. The early plug is removable, with brass hardware. Later plug is molded. Looks like you have an early receptacle and a later inspection lamp.
Early lamp with removable plug (from the RAGINGMATT collection)
Plug detail. (RAGINGMATT)
Later lamp with molded plug.
Plug detail.
I think there is plenty of depth in the receptical, it just barely starts in before it hangs up. Think it's just old and WD40 isn't enough.
Not to change the subject too much, but look what came on the Teal Shpeal:
My 64 still has its cover, all be it's shot to hell... :)
Not to change the subject too much, but look what came on the Teal Shpeal:View attachment 1832401
The socket on your 71 is black and this cover is ribbed on the side. Similar to this one that was on eBay recently.
The socket on your 64 is brown and the cover is not ribbed (based on the manual picture) and this one. Looks like at least 2 different versions of the firewall mounted socket, each having its own type of cover.
I have both versions of socket (early brown and later black) and also two “Easily removable covers”. Just not sure if they have ribs or not but both are black for sure. I will check and report back.
If you come
If you come across the brown cover, I'd be interested in buying it from you!
