Pre-1980 FJ40 VIN Information
I have access to 2 Toyota FJ40 Land Cruisers. I'm guessing one is a '71 and the other is a '79 based on body style. I have the VINs, but they are both pre-1980. Where can I get some info to help me determine what year they are exactly? Any help is appreciated.
Here's a vin number table complements of SOR.
So, if my VINs are 23890 and 75886, then I'm looking at a 1964 (March) and a 1969 (November)? I'll put up some pictures as well.
Yes. And welcome to Mud. :flipoff2:
Pictures
Here are the 2 I get the pleasure of restoring. Not the best pictures, but it gives you an idea. Now I just need to find a good place to start looking for parts....I'll also need some good suggestions for a place to get a new engine.
I was able to identify the years based on the VINs. I used the chart posted earlier. I've got a '64 & '69. Any suggestions for parts and engine?
floor shifter in a '69 ? - looks later to me
Specter Off Road for parts. A bunch of other places also ( check the internet ) and Craigslist for local and distant owner parts. MUD is also a great place to find parts. Nuclearlemon is correct, match your Vins from the front frame.
No transfer case shifter though Claudia, so reckon it was converted from there-on-the-tree. Also obviously not original shifter boot. Also does not have flush rear windows on hard top which were introduced in '72.
That is not a 64 or maybe the frame. Heater, padded dash, vent on the cowl, hard top, transfer shifter, glove box door, knobs on the dash, reverse light, emblems on the rear and side marker lights are all things you would not find on a 64. But all would be correct for a 70/71.
The vent window in the rear side window, that mirror on the side door and the gas door would only be on a 77/78 correct?
Did you check for a Vin plate on the A pillar.
aftermarket floor shifter boot, plus look under the steering wheel..the piece where the column shift lever was is still there. floorshift is a conversion
makes sense - mine was already converted when I got it
I will definitely check the VIN on the bumper. The inside picture comes from the FJ40 under the shed (the later model). Out of curiousity, why would someone swith the VIN plates? Also, if the VIN plates have been switched, is there a place I can go to get a new plate and stamp the original VIN?
Also, thanks for the welcome!! I'm really excited about restoring both of these. I plan on keeping the older one for myself, and working on the newer one with my son for him to have.
The one outside is the later model from all appearances: it's a '77 or '78, where the one under cover is a late '69 ish-'71.
Any chance the one is 275886? That would put it right on the money for the year...
