are you affiliated with the above company with cool parts? Other than the cost of a Toy 8sp, is there any advantage over the 8HP trans?
Sorry, got carried away and pretty much did not answer the second part of your question.
Gearing is slightly different. On paper I think I prefer the ZF over the Toyota transmission is I just look at how the ratios are.
However, I am not so sure in real life I can tell the difference in driving identical 80's with different 8-speed transmissions.
Maybe drag racing, but who cares at that point. 6000 lbs of steel racing down the street. I don't think 0.02 sec difference is enough to make a difference.
Anyway here are the ratios for the two transmissions.
Toyota 4.79......... 2.81.... 1.84... 1.43... 1.21... 1.00.... 0.82... 0.67
8HP70.. 4.714...3.143...2.10... 1.667...1.285....1.00...0.839...0.667
I tried to place the ratio in such a manner so one can easily see how they stack one over the other.
Also Toyota's 8-speed transmission's second gear almost matches the 80's first gear on the 4-speed.
Essentially you could start in second gear (2.81) and and it feels the same as the original transmission but what follows after will be totally different.
On the 4 speed it drops from 2.804 to 1.53 whereas on the 8-speed the drop is not that sharp.
You can see why on paper I prefer the ZF since you could start in second gear (3.143) then third at 2.10 and the fourth gear still lower than on the Toyota keeping the engine rev'd up in the powerband really nicely.
Again this is all speculation on paper.
I have no idea how they will behave in real life. It may all be totally different then my theoretical scenario.
