Hello! So recently my FZJ80's rear hatch could not be open from the outside. Luckily, I could open it from the inside so I was able to make do until I had some time to crack the panel open and investigate.
Upon further inspection, there is a joint where the exterior handle connects to the latch release assembly. This joint is basically a rod with an L-shaped end covered by a plastic clip that snaps into a loop/hole on the latch release assembly. Part of the plastic clip is broken, so the rod will not stay in the loop/hole. I have no definite idea what the part number or any identifier would be for this.
What I have found is this listing on Amazon. The product description doesn't mention it fitting Land Cruisers, but I haven't found any other 'Door Lock Clips' that do.
Any help or information on a part number, name, or any other means of acquiring one would be greatly appreciated.
Attached is a photo of the assembly from this thread, which I modified to add an arrow pointing to the clip in question.
