Pig drivetrain questions- 2F/H55/Splitcase
Cool thread. An H55 swap in my 76 is on the "maybe" list. Does the top cover that the H55 comes with work well on the piggie? I am co concerned about shifter placement. Thanks.
Subscribed, thanks for sharing.
The driveshaft length is 28 3/4. That length will almost certainly be different than stock due to the way I installed the shackle reversal kit. I can’t wait to see how you figure out the fan clutch. I tried that too but didn’t retry when all the stuff I had didn’t fit. I used a Ron Davis 4 core radiator with a trans cooler. That may be wider too?
To close the loop on this I got the motor and I have the fan clutch and fan and it’s dead on balls 8” head to tip of the fan.
Would you post the Cruiser Outfitters part numbers on those. I need to do a fan clutch upgrade on one of my rigs and this length looks right
Prada, Tundra 17" is FANB75020
Clutch needs to match your waterpump
I’m using a non-oil cooler waterpump from a FJ40
Part number is on page 1 of this thread
Water Pump - EGW61070
Fan Clutch - FAN61120
Fan Blade - FANB75020
:D
:D
Is this fan clutch special in any way? As in shallower?
Is the early waterpump I’m using shallower than a 60 waterpump?
The fan clutch is the standard height. The water pump is the same as the 60, just different config. The fan blade was really the key to the lower over-all-height.
So a 60 series pump with oil cooler and this clutch and fan blade will have same dimensions as the without cooler pump? This is great work, guys. I had given up on a clutch option for the pig...
