Damn that looks good Chuck!!! Gotta get by and see'r again!!Finally some updated pics ;p
It sits a bit higher & wider in the rear since the last driveway shots. I didn't feel like messin w/ the roof rack this time. I think it looksw/o it.
Nice exhaust setup. Did you do any breaks to make pulling the exhaust "easy"?
That was one of the minor complaints I had with the exhaust in my pig.
I see you used a flex joint in your exhaust. Any previous experience with them?
using extensions w/ ujoints to help. I feel the flexhose is necessary or you'll end up cracking the gasket at the header flange when the engine flexes & the muffler is hardmounted to the body. I didn't run a flexhose in my 40 & that's what happened. I've since installed one in that rig. I see your at the point of exhaust install in you build. You doing it all yourself?There's POR 20 now? Is that from the makers of POR 15?
;p Not a chance in that happening. I'll update the thread when extra fund$ are available. Till then. all my projects are on hold![]()
