PIG + Chebby Avalanche Trim =?
Most of the major cuts have been done. Frame is clean from spring mounts in preparation for coils & links. Started a little patchwork on the tailgate too. I H8 when welding, you keep burning larger holes in that rusted sheetmetal! Stay tuned.......
I shed a tear for that pig body which was in pretty damn good shape but I certainly cant complain since I chopped the crap out of mine. As for those front mounts if I had what you did right there I would have been happy mine were so rusted that I had to fab the whole thing up off the frame and the body.
When I did some floorboard rust repair on mine, those mounts were packed with dirt too. Not a whole lot you can do about it really, unless you want to drilla few holes in each and add some rubber plugs, then remember to suck 'em out with a shop vac every couple of years.
Anyways, I'm thinking about mixing the lines of the 55 and a Pontiac Aztec. What do you guys think?
I wonder....
I decided it'd be better to go ahead & find a gas tank & do the mods while access to the underbody will be easier for welding while the rear is off. So, I found a tank from a '94 S10 Blazer & started making the skid. The tank fits perfectly & it also has a built-in fuel pump. I've got the mounting figured out, so you'll see that next........
Uhhmmm....OVERKILL! :) Geez..you plan on parking that thing on the skid plate or what? ;)
Gas Tank Skid Update:
Almost done with the skid. All I need to do is weld in some 1/8" perforated metal which will be a task cuz I gotta bend it around the corners. Gotta polish up on my blacksmithin' skillz.
Approx. how many gallons does it hold?
It's a 20 gallon tank.
especially if your running a GM TBI engine, then you have solved the fuel pump issue : )
Wouldn't even think about the GM option - I'm a hardcore 6 cyl dude! I would do the GM fuel injection though.....
Hey McCoin, this is a forum for 55 owners, not "former" 55 owners. Now, git back to your Toy diesel forum.....
Great job on the skid plate. What kind of tools are you using (welder, bender type). Good idea on the gas tank too. Did you make the mounts too? Keep up the good work!!
I fabbed all the brackets, mounts, etc. It was very time consuming but well worth the piece of mind that my tank is protected from any trail obstacles. My main fab tools are a JD2 bender, which is quick-mounted on my trailer, & these two - Lincoln Procut 55 plasma & 255 mig welder:
