Paint over rust and other stuff.
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
I have been searching through the threads on protective paints for the under side of MY 40 and especially the 55. I think I'm sold on the Rust Bullet brand just because it is so easy to use.
My one problem was it didn't come in black until recently. But I had my doubts on it's ability to be sprayed. So I e-mailed the manufacturer. Here was his reply.
"Hello Marshall,
Yes you can spray BlackShell with an HVLP at 40 psi and a 1.4 tip, Remember to run some xylene or acetone through the equipment prior to starting and after each coat. It takes BlackShell 8-10 hours between coats, when you can’t transfer any to a gloved finger tip it’s ready for another coat.
Sincerely,
Frank Ciglar
V.P. Global Operations
Rust Bullet, LLC
Frank@RustBullet.com
www.RustBullet.com"
Here were the pics he sent.
I think I am sold.
Photo 2 and 3 are the same car? Amazing.
Any chance it will come in an aerosol can?
Abraca-Presto.
I am sure that only took an afternoon! :censor:
If you use zero rust, it can be sprayed using the same equipment, thinned with lacquer thinner, xylene or acetone. Several coats can be sprayed without waiting long periods of time. Let it flash and give it another coat. Plus it comes in an aerosol can which is really handy for spraying underneath and touch up. Gravity feed hvlps are hard to use for spraying into tight overhead areas because the can is on top.
Using Zero Rust on hardtop
Could this product be used along the outer edge of a hartop? Would it be harmful to the fiberglass?
i don't really see what the relavance of those pictures he sent was. that could be done to anything, with any kind of paint you still gotta clean the stuff and do a little body work. and honestly the after shots look pretty shoddy, like they just painted right over the dirt and rustyness. is that it's intention?
sorry no real help in this reply, just don't be blinded by a universal before and after shot.
i've allways used por15 with great results, is this stuff different?
I also have read up on these different rust prevention paints, zero rust, por15, rust bullet. I have found that they all do the same job. Zero Rust is a great product, and it comes in different colors, which is a plus, you can put the stuff on anything. Rust Bullet is supposedly better, and it will last longer without peel. However, the manufacturer (IMO) stretches the truth a little with the performance of the product, but do not get me wrong rust bullet is still an excellent prust preventer. As for por15, I have heard that Zero Rust and Rust bullet are better only because they will last longer and not peel (but i have not used the stuff, so i could be proved wrong.)
If I was you, I would stay with rust bullet, its simple, you can paint over it, don't need a primer and is very tuff. The stuff can also be sprayed on, like you have found out.
There's another product sold by Eastwood called Rust Encapsulator. They published extensive testing and results that showed it to be as good or better than POR15 in direct comparisons. It can be used as a primer directly on bare rusty metals, can protect against further rusting, and is compatible with most any filler primer.
It does come in aerosol cans if preferred, and the first thing I noticed was that it isn't anywhere near as toxic smelling as POR. Also doesn't require the preparation that POR does, and doesn't require the use of proprietary products to make it do it's work as POR does.
They also have a topcoat product called 'Chassis Black' that is available either matte or gloss black. It's a thick stuff that seems very similar to whatever Toyota used originally.
I have used the Eastwood rust encapsulator with good results on a utility trailer I rebuilt. The trailer had not seen paint in 20 years. All I did was wire brushed the rusty scale off and then applied the product. Painted with rustoleum. It sits outside in the elements and not a bit of rust has shown up in the past 2 years. I am getting ready to paint my axles and will probably use the same process.
I have used the POR products extensivly over the last 10 years and the Eastwood system as well. I'd say over time and considering all of the pain in the ass, that I'll stick with the Eastwood system over POR because like you said, there is less prep and I like the spray cans. I've seen POR fail by peeling and when you call and complain, they offer you a free can of paint. Never had that problem with Rust Ecapsulator from Eastwood or the former product Coroless (What they used to sell, they sell Encapsulator now and say it's the same thing).
-Stumbaugh
Marshall,
I have had REALLY GREAT results with Rust- Oleum oil based paint.
I purchased some semi gloss black at WalMArt for $7qt.
I added a lil acetone (10% volume) and sprayed it on with my compressor/gun.
It took about 12 hours to dry, hard as a rock.
Best of all it is readily availble and cheap. 2 cans is way more than you need.
It works REALLY REALLY REALLY well.
Marshall,
I have heard that it peels after a year or so, did i hear wrong?
and by the way, that undercarage looks great!
I've never had a problem with good old Rustoleum. IN fact, a friend of mine refuses to use any but and says its as good as anything else. I have to shamelessly admit that at times I don't use it because I think the corroless/rust encapsulator is probably just a little bit better.
Nothing wrong with Rustoleum, IF you do good prep work. With paint and welding, it's all about the prepwork.
-Stumbaugh
I have a couple of problems with Rustoleum. One is that for it to hold up for any length of time the surface needs to be prepped more than for Zero Rust. Rustoleum recommends that a red primer be used on rusty metal before finish is applied. Zero Rust just needs to have the loose material removed and scrubbed with their prep step. The prep step is inexpensive and can be mixed in any amount. The second problem is that Rustoleum needs to be scraped and sanded to re-coat again. Another coat will not adhere properly if its not. Zero Rust can be used for several coats if allowed to flash (30min) between coats. To re-coat at a later time all that is needed is a slight scuffing with a synthetic scuffing pad. Third Rustoleum takes a lot longer to dry before it can be handled. Usually Zero Rust can be handled in a couple of hours or so depending on temp.
Zero Rust was developed for industrial purposes. Rustoleum today is basically a consumer product that uses fish oil as part of it's rust inhibiting formula.
Hi All:
I have used both the Eastwood "Rust encapsulator" and "Rustoleum" paint while doing a 2/3rds body tub swap, and rear frame reapir on my FJ40.
I am more impressed with the Eastwood products, thought they do require the two step process of a primor and a top coat. Admittly, the Rustoleum anti-rust spray paint has worked well so far, but the "Rust Encapsulator" seems to produce a thicker, tougher coat on the metal.
I also used an undercoating that Eastwood sells. It is like the "cosmoline" that the Army used to coat metal items for long-term protection. The product comes in a semi-liquid state, but dries to a oily/waxy finish that is flexible yet tough to impact.
This "cosmoline" like product is cheap and easy to apply, if a bit messy! :D
Regards,
Alan
