cool!!!!!!!!! I think I may do this also!!! great post Cooler!!!
I used a big long screwdriver jammed into the flywheel teeth and jammed against the frame rail to keep the engine from turning.
Seems the copper gasket that was OEM in this location needs to be tightened pretty darn tight. I did not get it tight enough and it's position does not allow a wrench or socket to get to it.
I will have to remove the shifter to get to it. I will put Teflon tape and an o-ring on it just like I did the oil plug.
Your PS reservoir may be inside the air cleaner.
Test fit before going any further.
