- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
OK...
Motor is a 2/71 F engine with maybe 130K on the clock, never rebuilt.
I've got 8 qts of new 20W-50 in the pulled and cleaned oil pan...
Oil pump screen was removed and cleaned.
New oil filter, new braided oil lines, Oil regulator taken apart, cleaned and re-installed (more on that in a sec)
I have a mechanical oil gauge hooked into the oil filter housing and laying on top of the engine so I can see it.
I have the dizzy out and a old F engine dizzy shaft chucked into a good corded drill.
I insert the shaft, engage the slot, and pull the trigger expecting to see oil pressure almost immediately. After 30 seconds nothing. Hmmmm....
I pulled the oil pressure sender and new oil dribbled out. Ok that's good. Spin the pump another 30 seconds...no pressure...
Then I remembered that I had left the oil regulator adjusting plug most of the way out. Screw it in about 1/2 way. Spin the pump and
20 lbs pressure! Seemed a bit low so I cranked it all the way in, spun the pump and
only 25 PSI.
So how much pressure should I expect to see just using a drill to build pressure?
I've spun it for a total of maybe 4 minutes with no change in pressure. Thoughts?
FWIW I seem to remember the oil pressure being around 40 using the exact same gauge the last time it ran.
I also hooked up my brand new Auto Meter electric oil gauge and it reads the exact same thing.
only 25 PSI.So how much pressure should I expect to see just using a drill to build pressure?
