Its hard to tell in the photo without knowing the actual measurements, but it looks like your shackle is too flat for that spring length and unless you absolutely kill your uptravel and limit spring compression with bump stops, you are going to max out shackle movement before your spring goes flat. This will then put the spring into a bind and potentially bend/break the main leaf. When setting up flat-ish leaf springs, you need to take the pack apart and setup shackle angle so that you will never max out the shackle travel before the spring goes flat and starts to invert.
Measure the length of your spring, eye to eye along the main leaf using a soft tape. Not the straight eye to eye distance at static free-arch, you need to total length if spring was flat. Then set your shackle flat, straight back (without leaf spring attached to it). Measure from your front spring hanger eye back to shackle hole center. If that distance is less than the eye to eye length of your leaf spring, you are going to have an issue purely based on leaf length, shackle length and shackle hanger location, and this ignores a lot of other setup concerns.
As others have stated, I think you're putting the cart well before the horse here, setting shackles up without any body weight. Shackle length, shackle angle and shackle hanger placement need to be adjusted and decided on with full weight of vehicle otherwise your are likely doing this all again in the future to make it right....
