Aside from the oem height replacement coils, I've come to the conclusion that it takes at least a J up front to get that elusive "level" stance.
I'm considering increasing the lift on my rig. From what I've come across while searching, even an 860 out back in conjunction with 850's still appears a bit "stinky". Hey, correct me if I'm wrong.
Nevermind about 10,000lbs of camping gear, and no input on spacers needed. After all, an 850+1" spacer equals a J doesn't it.
Come on people, lets debate the hell out of this
. The 863s have paid off for towing, though, and I still want that aux. tank and maybe drawers also. So I keep the 863s and live with the "stinkbug".
If the headlights are properly aimed with normal load and a rear bias load is added they will be high, regardless of spring. The ways to deal with it are; adjust with load and deal with them being low when unloaded. Adjust for normal load and deal with them being high when loaded or readjust each time load changes. Pick your poison.
. leveled lifts for the 80 all seem to be hybrids with the front being usually 1" higher than the rear. whether it be slee 4" up front with j's in the back or med/heavies all round with 1" spacer up front. not sure why lift manufacturers make it like that. good thing most lifts are available as individual front and rears... so you can fine tune em as you like.
