parts and harness
Started cleaning up parts. Earlier in the year when I did the mini-swap front axle rebuild with Tornadoalleycruiser, I used MOfj40's shop to clean up the steering box also. Just pulled it apart, cleaned all grease out of it, checked it all over. So, this weekend, I put it back together, cleaned and sprayed it black over the weekend.
Also I found out on coolerman's website a clean wiring diagram that is awesome! Notes B= black not blue, L = light blue not leapord print. Also found on PDF's you can enlarge them, and it will print them out in tiles with overlap if you want. So, printed it out, used kids colored pencils to give it POP, and then used packaging tape so it will survive. VERY helpful to be able to read the wire colors and what everything is going to.
So, earlier, buddie Rob and I laid out the old harness on a 4x8 sheet of plywood. Now, I laid my new harness from
EBAY over top of it, and started running it all over the place. Looks like the big area I have to add wires is the hazard switch, fan, and wipers. Other than that all is good.
Question: I am thinking about putting the stereo under the driver seat in the lockbox (toolbox) I am hoping the remote will control it. My thought is that I am not going to break up the dash, and as I want to keep the top off as much as possible, I don't want to advertise my $75 stereo is there. Speakers are going to be hidden under dash as best as possible. Will run lines to the back, but not planning on rear speakers for now.
