Oil?
Texas
What oil are you running in a 93/94 FJ80 with 200k plus? Manual says 10W30. Just curious if there are any recommendations for higher mileage. I won't run synthetic.
I am partial to Delo 400 15/40. You will get as many answers as there are members here. If the bottle has the correct API certification printed on it then it's a matter of which bottle you like the looks of best or maybe what is on sale. This is especially true when extended oil change intervals are not part of the vehicle maintenance plan.
Ok, I'll bite, why won't you run synthetic?
15w40 rotella T6
No such thing. Either you're running 5w40 Rotella T6 or you're running 15w40 rotella T
That said, I run Rotella T6 in everything I own. Buy it by the 2.5 gallon jugs.
My truck likes oil and any oil I give it.
Amen to that. Mine requires at least a quart a month to keep the oil light from coming on. It burns or leaks enough that the only reason to change the oil these days is to put a fresh filter on it.
I keep thinking I need to try one of the "snake oil" treatments to see if I can get the valve seals to swell up for at least a little while, but I never see much other than Lucas stuff around here & it hasn't seemed to make any noticeable difference.
I use the 10W-30 in my '93. I tried 15W-40 Delo once and feel like it was too thick for my engine's tastes. Oil pressure (OEM in dash) read near max all the time and I got a new sound in the valve train that went away once I went back to 10W-30. I'm also a small oil filter guy. My newly rebuilt engine has all new seals so I'll probably go synthetic, but I might not because those 8 qt. of oil and intervals of less that 7500mi don't make financial sense. But as you've seen here, sense is not always why we do what we do.
Rotella is cheap at wally world. Nothing is gonna stop this beast from leaking, and the 1fz-fe is well known for not giving a crap what you put in it, as long as it's not piss or sugar. :hillbilly:
I have been running T6 (synthetic, sorry) in my 80, though I ran the first interval after my head gasket job with valvoline racing oil for the high zinc since the shims were replaced/moved around for a little break in action. Regular Rotella would be a good non synthetic for warm areas. I suppose something thinner, maybe 10-30 for cold winter zones.
Piss is an acceptable alternate for the 3FE.
The 3FE, on the other hand, doesn't mind piss one bit.
Correct.
Is it a Texas thing? @LS1FJ40 ?
Sorry.
F@&$ Texas!
I run Rotella T5 15w-40. Contemplated switching to something thinner since it is winter. It was about 6 degrees this morning. Started just fine.
Whats a good winter weight oil that has a good additive package in it? (zinc)?
From what I've read the Rotella 5w-40 has a good additive package. I'm due for an oil change and will try it. For grins.
I read on an Audi forum or something where Blackstone tested it with the T6 5w-40 and they were "virtually identical" as far as additives.
What does it mean when I see alot of steam coming out my exhaust?
And I'm seeing milky looking stuff in my oil?
:deadhorse:.
