oil use please help
Thanks Wayne. I realy think this is the only thing it can be. Has anyone ever had any luck with soaking the top of the pistons to free the rings up? Any chance with more daily use they may free up? I know i am reaching here but the thought of tearing down such a good running motor makes me sick. thanks
Found your thread. Better to just send me a link next time.;)
As Poser and other have said, consumption, especially at that level, without evidence on the spark plugs, is very unlikely.
Drive it.
I tried this on mine over last winter since I don't drive it in the salt. I would back it out of the garage, let it warm up, pull it back inside, pull all the plugs out quickly and put a turkey baster full of marvel mystery oil into each cylinder. I did this 3 or 4 times and went through 2 bottles of mystery oil doing so. In the spring I drained the oil and the first time I took it for a drive it was still smoking under load, and the oil consumption if anything got worse. Like you I have no signs of excessive oil consumption on my plugs. Due to my leak down test results I know it's rings, and it's getting torn down in a month or two to investigate further, and then i'm doing a rebuild. Mine has always turned fresh oil completely black within a few hundred miles too, another sign of worn rings. Yet it drives fine, I had it out yesterday and took my dog for a ride. If this truck sat for any period of time (which is very likely considering the mileage) it's probably got stuck oil rings. The machinist who is going to do the work on my motor says he sees this all the time on stuff that sits.
It's evaporating!
Serioisly. If it isn't leaking oil externally or internally, the onlything left is burning it. I've had engines that used a lot less oil than that and they fouled plugs regularily. If this is not showing up yet you haven't waited long enough.
Something just doesn't add up.
subscribe...
because I want to see the answer when you find out...
"Which would make perfect sense considering the truck sat without being started for 7 years according to the previous owner. What I do find odd is that before the last 5k miles or so I never saw it smoke at all. Now it's smoking to the point it's kind of embarrasing to drive. "
My situation as well, pretty much, including a sooted up tailpipe and spark plugs that smell oily, and really low oil pressure. But it was running great. So it's torn down and in the machine shop right now. We found bad bearings, rings and worn cylinders. Yeah, pretty embarrassing blowing a cloud of smoke into the window of the Prius next to me.:o
Yeah a really really old thread. But it never got updated unfortunately, so us’ns with enquiring minds would have liked to known what the resolution was/is.
