The questions are:
1. Is the oil cooler on a 1FZ-FE full flow or partial flow?
2. Is there experience with these coolers getting partially plugged?
3. Can the front exhaust heat shield cause the oil cooler to run warmer?
The back ground is after much experimentation with oil and oil pressure gauges an apparent oil pressure problem is under control. The issue started with very low oil pressure, about one needle width of zero at idle and barely above the low line on the gauge at 2400 rpm. This was the result of a quick oil change at a nearby oil change store.
I then changed the oil my self, replaced the filter with a premium filter and used Mobil One 10-40. I also removed the front exhaust heat shield and temporarily installed a mechanical gauge. The gauge read 60 psi when cold, about 55 psi when warm, and about 15 psi at idle. It quickly rose to 30 psi when driving at low speeds (1400 rpm or so). These are all reasonable. Additionally either the removal and installation of the connectors on the oil pressure sensor or the removal of the front exhaust heat shield seemed to increase the oil pressure a bit.
Measuring the temperature of the oil pan indicates 205 degrees after a hard run up a long hill on a 90 degree day. After 5 minutes at idle the temperature dropped to 175 degrees. There is a moderate 5 PSI change in pressure with these readings. The current conclusion is the pressure is fine and the only remaining questions relate to oil temperature.
Should the cooler do a better job of maintaining 175 degree temperature even on a hard run up hill?
Is 205 degrees to warm for oil?
What is the optimum oil temperature?
Advice for someone chasing an apparent oil pressure question:
1. Measure the pressure with a mechanical gauge.
2. Use a premium filter and oil that will maintain viscosity at over 200 degrees.
3. Make sure the connections the the gauge are clean.
4. Try removing the front exhaust shield.
IMG_2149
