I've been wanting to add a good, accurate Oil Pressure Gauge to my 80 series because the OEM unit seems to work about as well the infamous Water Temp Gauge (basically leaves you wondering).
I already have a ScanGauge to accurately monitor Water Temp and Voltage, but I had no way to 'accurately' keep track of my Oil Pressure or Transmission Fluid Temps. I wanted to keep my OEM sending unit and gauge functional, but ADD a better gauge.
So I ordered a couple of 'Auber' digital gauges and started looking for a good place to put them.
I wanted small gauges that I could mount someplace without having to go the Pillar Pod route.
So I got an amber gauge for the Oil Pressure and Red Gauge for the Trans Temp.
I'll do a write up on the Trans Temp install in a separate thread at a later date.
For my purposes...it would be necessary to use Two Sending units for the Oil Pressure (one OEM the other Aftermarket). In order to do that I needed an adapter. No big deal, found what I needed on Ebay.
Only concern was that in order to install the adapter, I would have ended up with a fitting about 4"-5" long hanging off the side of the engine on a 1/8" pipe nipple. Hmmmmm....that doesn't sound like something that is going to last.
So...this brings us to the subject at hand (RELOCATING the sending units).
Found a kit made for doing just such a thing:
Continued next post:
