That looks and sounds absolutely bionic!
I hope it works like Steve Austin. So far a cautious thumbs up.That looks and sounds absolutely bionic!
Thanks and appreciate the feedback. Only 1000 ft here.what is your elevation there ?
That was my thought as well, though it is better than the wobbly 13" I was getting before the manifold fix. Compression is between 144 and 147 for all 6. Adjusted the valves prior. I think the only other thing I haven't changed was the PCV hose. Could be that - next on the list.at 1000 feet, you should be making a little more vacuum than 17'', I believe, but perhaps some of the other sea level and above 2F owners can chime in here. perhaps a valve adjustment and compression check is in order? or maybe you have some other vac leaks.
oh ya. check that area. that can be a huge source of vac leakThat was my thought as well, though it is better than the wobbly 13" I was getting before the manifold fix. Compression is between 144 and 147 for all 6. Adjusted the valves prior. I think the only other thing I haven't changed was the PCV hose. Could be that - next on the list.
Much appreciated. And thanks for the reminder. On the agenda for this weekend and something I should have done long ago.That's such a nice truck. I hope you have some anti-theft method installed that you won't describe here on Mud. A truck that sharp would be tempting to a lot of lowlifes. Just my .02 worth!
