forum.ih8mud.com
is that adjustable rear upper control arm an older design? I'm seeing 2 adjustable ends but the website shows only one end being adjustableTrail Tailor Adjustable rear upper control arms. Used for approximately 500 miles. $150
When I bought it I believe he had two options, with this one being the more convenient and more expensive option. You can mount it up completely and then adjust it by rotating the shaft.is that adjustable rear upper control arm an older design? I'm seeing 2 adjustable ends but the website shows only one end being adjustable
@Roxx?Looking for a 98-99 Land Cruiser rear axle with the OEM diff locker
I got one if alex passes on it.Looking for a 98-99 Land Cruiser rear axle with the OEM diff locker
Great, if he doesn’t want it I’d be happy to buy, just let me know.I got one if alex passes on it.
Bump $400 for club members or make an offer100 series Trail Tailor Hidden Winch Mount - brand new in box, never mounted.
Asking $495. You avoid tax and shipping. Can deliver within reasonable distance of Alexandria or McLean.
Hidden Winch Mount 100 Series
Made from CNC cut and bent 1/4" steel with black powdercoating Designed to fit up to a ComeUp 12.5rs winch with maximum dimensions of 24"W x 8.1"H x 6.3"D Cutting of the factory front bumper crossmember and cover required for install Re-uses all of the OEM cover tabs for a solid mount Toyota...trail-tailor.com
if that falls through hit me up on thosePENDING SALE
5th gen 4runner white knuckle off-road sliders, have U bolts just needs new nuts.
Can bring to the swap meet later this month if needed.
listed for 500 is the classifieds. 400 to any CLCC member
100 Series goodies. All pick up only in Alexandria, VA (Del Ray neighborhood).
Used 100 Series Front Runner Slimeline II roof rack with the following accessories:
Ratcheting Spade Mount
Double Jerry Can Holder X2
SS Tie Down Rings
Wolf Pak Mounting Brackets X3
Water Containers X3
Water container mounting brackets X2
Spare Tire Mount
Mounting hardware for the rack included
This rack is less than a year old and performed flawlessly during our Skeleton Coast expedition last year. Now that the truck is in the U.S., it mostly visits the grocery store and needs to fit in a parking garage at work...so the rack has to go. $1,500
What is included in the sale:
What it looks like fully loaded on expedition:
1 Yokohama Geolandar A/T G015LT275 /70 R18 125S E1 OWL mounted on a steel Tundra spare tire rim. This tire is mounted and balanced, but should be used as a TRAIL SPARE only, due to minor sidewall damage (caused by rubbing while mounted on my dissent rear tire carrier). This tire has been used, but there are very few miles on it. $180.
View attachment 3873513View attachment 3873514
Diff Drop (seen above). Unknown manufacturer. Very slightly different height than a Slee diff drop, so will not work with Slee skid plates. $50
I may buy those rear upper control arms!Seems likely I will be bringing all this stuff to try and sell at the swap meet on April 27 (except the roof rack, which I don't have an easy way to transport, but a buyer would be welcome to follow me home afterwards and load it up or bolt it on).
I realize I also forgot to post up the factory air intake and air cleaner box I took off my truck to install the cyclonic air filter. Only has ~100K miles on it. Might help someone who had to JB Weld a broken nipple or some such nonsense ($150).
I'm potentially interested in the roof rack but am unable to DM you. Can you send me a DM? I have a few questions about it.Seems likely I will be bringing all this stuff to try and sell at the swap meet on April 27 (except the roof rack, which I don't have an easy way to transport, but a buyer would be welcome to follow me home afterwards and load it up or bolt it on).
Thanks for mentioning you were unable to DM me. Buried deep in my settings I found that nobody has been allowed to DM me. All fixed now!I'm potentially interested in the roof rack but am unable to DM you. Can you send me a DM? I have a few questions about it.
Thanks!
forum.ih8mud.com
I'm looking to purchase a Hi Lift mount for an FJ40. Unless I get rear swing out, I can't think of a better method to mount it than the method that was designed to put it standing upright on the passenger-side running board. It looks like a snag waiting to happen, but @StaleAle promises to pay for any damage I might incur. The mount doesn't appear to be made anymore. Does anyone have one laying around that they want to part with?
