OE PCV hose variations
Id still like to buy a cloth hose from someone
First post has been updated.
This is from an early '75 donor motor.
from you revised post(sunday)....which you turned into a for sale ad, but now with restictions.
"Note: I have thrown all the bad hoses away. All these hoses are useable and available for purchase...in package deals with at least 200 dollars of ‘regular ‘ merchandise."
Mark, you would not even give me a price(2 months ago) for the hose when I odered the carb spacer, if you would have said a $200 order was required I would have made a $200 order(of regular mechadise, whatever that may be classified as) ........heck if you told me the hose was $100 I may have paid that at the time. This had to be one of the most odd experences ordering from a Mud vendor I have probably ever had.
My 2F's all use 10mm PCV hoses , Fittings , & Valves .............................;)
The barbs or anti-pull back lips or " Beads " portion on ALL the metal tubing , fittings and valves is 11mm
@wngrog
I got about 40" of 3/8" 9.5mm hose from a bulk spool at AutoZone to replace the one in post #24. It took way to much time to find for something this simple. 10mm=.394" so it is half a millimeter (.019") too small, but it works. I wouldn't go too small with anything like a plastic brake booster barb that might break if it seized and needed removal.
Now, if I can only get the same life out of the PCV hose as the truck has from the original heater hose.
Bump for the search-challenged gentleman that called earlier today.😉
